broken tranny piece question
what piece is this? mine is broken (obviously)...i can't see how to remove it other than drill it out. there is a plug on the other side? do i remove that to unscrew it? or would i be better off swapping the whole tranny? here are the pics.
the good tranny
the good tranny with close up on the piece i'm asking about
my broken piece
thanks all....
the good tranny
my broken piece
thanks all....
Only thing I could think of is grind it down flat or a little further,
then weld in some kind of piece in the same shape with threads on the inside.
It won't exactly be an easy weld though, because I think the casing is cast AL.
But it Can be done, I've had a cast AL oilpan welded, and it patched up fine.
You need another tranny case. That one belongs in a dumpster at this point. I'd think any B series case would do. Transfer the parts over, check the clearances like it says in the manual and drive on.
