ecu b10 b12 question
Old Apr 30, 2006 | 10:44 AM
janz3n's Avatar
Default ecu b10 b12 question
ok did the mpfi swap , noticed today that the wire i put in to b10 is white and b12 is orange. its supposed to be the other way around. but when i switched them back my car ran like ****. and the ohms for the two extra blue wires from the dizzy keeps going down every time i check it. anyone have any idea why my car runs better the wrong way?
Old Apr 30, 2006 | 08:51 PM
janz3n's Avatar
Default Re: ecu b10 b12 question (janz3n)
in one writeup it says if you mix up b10 and b12 your engine will run severly retarted... i had to advance my time a little to get it running with b10 and b12 in the wrong holes. can anyone tell me if its possible for a engine to run with b10 and b12 switched?
Old Apr 30, 2006 | 09:37 PM
janz3n's Avatar
if im looking at my ecu plugs from the wire and count from left to right b10 is first and b12 is second on the bottom, is this correct? if it is then my b10 is white and b12 is orange. why does my car run better with these wires switched???!!!
Old May 1, 2006 | 07:18 AM
slpnz6's Avatar
looking at the plugs wire side...it should read like this
EX: 1-3-5-7-9-11-13
2-4-6-8-10-12-14
odds on top and evens on bottom..its the same for all civic plugs..
just double check everything
Old May 1, 2006 | 07:22 AM
janz3n's Avatar
Default Re: ecu b10 b12 question (slpnz6)
k well for somereason i put the white in b10 and the orange in b12 and it runs better the way it is now then switching them.. and iv driving almost 4000kms like this.
Old May 1, 2006 | 08:12 PM
janz3n's Avatar
ok so i swtiched these wires around all day and felt like the engine was getting better everytime i did it then went back to the wrongway, then i tried it again drove the car this time... ran really slow and the code 9 came back, switched the wries again.. drove the car ran really good and no cel or code 9 anymore.. why is my car running better wired wrong??????
JJ's civic
May 6, 2009 02:55 PM
894doorDX
Jan 18, 2008 12:39 PM
Crasian
Jul 15, 2005 08:00 AM
rice crispies
Jul 5, 2005 08:07 AM
leadtrum
Sep 4, 2003 10:50 AM
