I have a 2 questions I need answer about my turbo setup
Old Apr 30, 2006 | 10:24 AM
raysjdmh22a's Avatar
Default I have a 2 questions I need answer about my turbo setup
ok here's the 1st one do I need to replace the stock map sensor if I'm only running 5 to 7lbs of boost? I have the hondata with boost option
2nd one I have an issue with my radatior and turbo manifold setup, with my manifold and my turbonatice mounted it set way to close to the radatior were the top hose connects... there's no way to put the hose back on...but what I was think that if maybe I can run a smaller radatior like from a civic so I have room for my setup and then run the fans on all the time I think it my work... what do you guys think? do you think I would have cooling problems?
Old Apr 30, 2006 | 10:30 AM
98vtec's Avatar
moderator emeritus
Default Re: I have a 2 questions I need answer about my turbo setup (raysjdmh22a)
92-95 civic radiator.
Old Apr 30, 2006 | 11:09 AM
The Weather Man's Avatar
You shouldn't have to replace the stock map sensor unless you're boosting higher than that.
You can definately run a smaller radiator. Or get an aftermarket radiator thats the same size.
What kind of manifold are u using?
Old Apr 30, 2006 | 12:31 PM
Rosko's Avatar
Default Re: (The Weather Man)
stock map sensor should be good to 14.7 psi (1 bar)
Old Apr 30, 2006 | 09:10 PM
here's the manifold I'm running
So you guys are sure that I wont have any problem running a smaller raditaor? what would you guy think would be the best one to get, keep in mind I have a 99 honda prelude.. oh yeah would running a smaller raditaor affect my A/C at all? I think about running the fans on all the time....let me know what you think
Ray
Old May 1, 2006 | 11:52 AM
oh yeah, do you guys think I should run a apexi boost control with the hondata?
Ray
Old May 1, 2006 | 02:49 PM
BlueLude94's Avatar
Default Re: (raysjdmh22a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raysjdmh22a &raquo;</TD></TR><TR><TD CLASS="quote">So you guys are sure that I wont have any problem running a smaller raditaor? what would you guy think would be the best one to get, keep in mind I have a 99 honda prelude.. oh yeah would running a smaller raditaor affect my A/C at all? Ray</TD></TR></TABLE>
H22 swapped civics run their stock rad all the time and make well over 400hp.
Any civic rad. should work just make sure it is a dual core.
No A/C will not be affected at all by the rad. change.
Old May 4, 2006 | 11:43 AM
DIRTYsouthBB6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raysjdmh22a &raquo;</TD></TR><TR><TD CLASS="quote">here's the manifold I'm running
Is that a Drag manifold?
Old May 4, 2006 | 11:58 AM
chitownrida's Avatar
if thats the drag manifold, i dont see how you could be having issues with the radiator hose... more pics??
whole9
Jun 21, 2007 02:37 AM
zenon8890
Jul 8, 2006 12:13 PM
raysjdmh22a
Apr 30, 2006 11:45 AM
Speed PHreak
Feb 8, 2002 06:21 AM
