Timing Belt Wear normal?
Hey guys i just checked my timing belt out on my b16a and there is some visual wear. On one side the belt is worn. looks like it rubbed on something. Does it have to be replaced or will it be okay? Its like 1-2mm in on the belt. It doesnt look major but i am not sure. What would cause this?
THIS IS NOT AN ACTUAL PIC. THIS PICTURE SHOWS SIMILAR WEAR. MINE IS NOT AS BAD BUT IT IS SIMILAR.
Thanks
Thanks
well post a pic of your issue and we can help, but I think if you are even thinking it is an issue then replace it cause if it goes your Fuked.
imadigitalgod
Aug 18, 2023 08:01 PM
