95 GSR Launch...... Help a Rookie out...thanks
Old Apr 30, 2006 | 08:11 AM
95GSRBOI's Avatar
Default 95 GSR what rpm you should let go for better launch?
Modified by 95GSRBOI at 9:49 PM 5/9/2006
Old May 3, 2006 | 10:39 PM
2157 EH3's Avatar
Pratice on E21st at night
Old May 3, 2006 | 11:05 PM
RaceProfessor's Avatar
Default Re: 95 GSR Launch...... Help a Rookie out...thanks (95GSRBOI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRBOI &raquo;</TD></TR><TR><TD CLASS="quote">Hi there..
I just got a 95 GSR and I wondering how you launch your car.. Anyways, anyone who can help me I will appreciate it. Thanks again</TD></TR></TABLE>
Geezuz, I'll do the right thing and help the noob. I'll assume that your car is either stock or close to it and it's on street tires. Based on that assumption here's my method: dry rev it to around 3800 to 4200rpm, if it's a stock clutch slip it relatively quickly and modulate the throttle until you feel the car hooking then give it WOT. A decent 60' ft. for a novice driver should be a 2.2 so keep trying until you at least get to that. A 2.1 is quite good and a 2.0 is very good on regular street tires. Practice makes perfect. Good luck.
Old May 3, 2006 | 11:06 PM
K-EG's Avatar
Whats done to it?Whats your tire and wheel combo?
Old May 4, 2006 | 12:46 PM
2MUCHBOOST4U's Avatar
Default Re: (H23aEG)
heat the tires up realy good and lower your tire pressure and launch at 9 grand you should be good ...
Old May 4, 2006 | 05:39 PM
K-EG's Avatar
Default Re: (2MUCHBOOST4U)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2MUCHBOOST4U &raquo;</TD></TR><TR><TD CLASS="quote">heat the tires up realy good and lower your tire pressure and launch at 9 grand you should be good ... </TD></TR></TABLE>
LOL thats the way to do it
Old May 4, 2006 | 09:34 PM
If your "stock" GSR Integra went 14's, you don't need advice.
Old May 5, 2006 | 10:15 AM
Red Bull's Avatar
I launched mine at 3500 and i cut a 1.9 60ft with those crap *** michelins, exhaust, and a drop. The best time i hit was a 14.61 at 96mph. Thats the most that car was capable of i think with that setup...gl
Old May 9, 2006 | 05:19 AM
put a 100 shot in it (WET), heat up your tires and lower your tire pressure to 15 lbs launch in reverse at 9 grand you should be good !!
exx07a0b
Oct 14, 2007 06:44 AM
jordan_civic
Jul 18, 2007 11:54 AM
GQ 05YellowEVO8
Apr 1, 2003 04:38 AM
