clutch sound?
Old Apr 30, 2006 | 07:41 AM
teddy_dc2's Avatar
Default clutch sound?
boosted gsr, c.m. stg 3 clutch + f.w. about 1k of run time, when i got my muffler on, i can hear i squeaking noise like a belt would sound, it's coming from like the slave cylinder on the tranny. sound doesn't effect performacne but it's annoying. anyone with the same problem?
Old Apr 30, 2006 | 07:50 AM
s2kdre's Avatar
Default Re: clutch sound? (teddy_dc2)
throwout bearing is goin bad, mines doin the same thing after like 3,000 miles too. strong pressure plates always wear them out fast,
Old Apr 30, 2006 | 03:18 PM
mygsrtegn757's Avatar
same here... throwout bearing bad, clutch still in A+ shape otherwise. sounds like a squealing belt, and a vibration in the clutch pedal.. Centerforce bearing - $40... about 200-300 for a shop to install...
Old Apr 30, 2006 | 05:59 PM
teddy_dc2's Avatar
what does it do? am i in trouble or is it fine? doesn't seem to affect performance. yeah, the sound seems to change high and low pitch with the turn signal on. will it be safe to run like this? (don't want to go through the hassle of taking the tranny again)
Old Apr 30, 2006 | 06:04 PM
teddy_dc2's Avatar
is that part of the thrust bearing or tranny? is it something i can do myself? yeah i remember the thrust bearing wiggled in during installation. yeah clutch pedal vibrates. where can i find a solution?
Old May 2, 2006 | 05:22 AM
teddy_dc2's Avatar
help!??
Old May 2, 2006 | 09:31 AM
miketegra's Avatar
Default Re: (teddy_dc2)
I had what seems to be the same problem on my 94 GSR....kinda sounded like a cricket down in the tryanny when I was letting the clutch out. Replaced the PP, friction disk, and Throw Out bearing....noise went away. I'd say you have nothing to worry about until it starts getting louder. It's the bearing going bad and yes, eventually, it will fail, but I think you will have plenty of warning, and its gonna take a long time.....my advice though....replace it asap.
Old May 3, 2006 | 07:28 AM
teddy_dc2's Avatar
the thing is like brand new, from the first time i turned it on i notice the vibration but the sound finally got louder with the full exhaust. how long will it last?
Old May 4, 2006 | 07:55 PM
miketegra's Avatar
I dont know if this would really make a difference in this case, but did you grease the mainshaft and release bearing with high temp urea grease?
Old May 5, 2006 | 06:26 AM
teddy_dc2's Avatar
no, it was kinda dirty and i just put a new one in, there is like a gap of empty space on the clutch pedal before you can feel pressure, i think the empty space is causing it to wiggle and make the noise cause when i slightly tap it to a bit of pressure, the noise goes away. can you adjust the dept of the clutch pedal, too much empty space.
2000-em1
Transmission & Drivetrain
Dec 29, 2011 05:52 AM
wessieball
Feb 25, 2009 12:44 PM
phanatic
Jul 31, 2006 08:54 PM
vlc92189
Jul 23, 2006 05:01 PM
Aron Parsons
Mar 6, 2006 09:18 PM
