Camberkit question
Does anyone have or has installed this type of front camber kit - http://cgi.ebay.com/ebaymotors...QrdZ1
maby not that make but that style.... i just got some and im thinking bout it when there installed.. and im doin a 2.25" drop... and with this kit wont that cause the upper A arm to hit the upper frame support behind the fender? becasue it makes that A arm come out that much more?
yes it is low enuf that i need a camber kit.... i have the drop dude. i have a b18 swap too my camber eats my tires within 1000 miles....
anyone have any incite on this camber kit?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18aHatch »</TD></TR><TR><TD CLASS="quote">yes it is low enuf that i need a camber kit.... i have the drop dude. i have a b18 swap too my camber eats my tires within 1000 miles....
anyone have any incite on this camber kit?</TD></TR></TABLE>
2.25" is not that low,,and its probably not the camber thats eating the tires,,,its the toe,,get an alignment and have it set at 0 and you'll stop eating those tires..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">2.25" isnt that low,you dont need a camber kit...,,,just get an alignment when your done and you'll be fine..</TD></TR></TABLE>
i wish. my ef is lowered, i would guess, about 2 inches, and the #1 alignment place in town said i needed a camber correction kit; they wouldnt align it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">2.25" is not that low,,and its probably not the camber thats eating the tires,,,its the toe,,get an alignment and have it set at 0 and you'll stop eating those tires..</TD></TR></TABLE>
Personally, my Azenis last ~12,000 (and a hundred or so autocross runs) with -2.5° of camber... so if your tires are lasting 1000 miles, your toe is f'd up.
Even if you have zero camber... if you dont fix your toe you will still lose your tires in 1000 miles...OK, maybe 1500.
Now with all that said, if you are really into drag racing, then having zero-ish camber might be a good thing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STD ****** »</TD></TR><TR><TD CLASS="quote">i wish. my ef is lowered, i would guess, about 2 inches, and the #1 alignment place in town said i needed a camber correction kit; they wouldnt align it
I do mine at a race-alignment shop. Try other places. Just get zero toe, and enjoy... its true.
</TD></TR></TABLE>I do mine at a race-alignment shop. Try other places. Just get zero toe, and enjoy... its true.
ok. well the places i went to get an alignement wouldnt warntee it becuase they cant adjust the camber.... can somone please just give me some incite on these kits?? thats all iam asking... i already have the kit... i just need that simple ? answerd if anyone knows...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant »</TD></TR><TR><TD CLASS="quote">Personally, my Azenis last ~12,000 (and a hundred or so autocross runs) with -2.5° of camber... so if your tires are lasting 1000 miles, your toe is f'd up.
Now with all that said, if you are really into drag racing, then having zero-ish camber might be a good thing.</TD></TR></TABLE>
i agree with you, with experience. the front of my integra was slammed nasty, because i think i got "junk"2 lowering springs
. it was lowered about 3" in the front, and my camber was horrible. last summer i put Azenis on, and 3000 miles later they still looked brand new. i need my hatchs camber adjusted because it is going to be used for drag racing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18aHatch »</TD></TR><TR><TD CLASS="quote">ok. well the places i went to get an alignement wouldnt warntee it becuase they cant adjust the camber.... can somone please just give me some incite on these kits?? thats all iam asking... i already have the kit... i just need that simple ? answerd if anyone knows...</TD></TR></TABLE>
I have had them on for the past 4 years without a problem, at full extention they will hit. So the best thing to do is not pull them out as far as they will go. what I did was have them set loose..push the arm up into the upper frame them pull them out, but leave yourself a little gap there, then tighten them down, and there you have it.
hth
hth
I hate mine, I cannot correct for my camber without hitting the frame. Thinking about trying the adjustable ball joints. Plust they're very poorley made. I would definately like to revert back to my stock upper pivot mounts.
