hp gain with Spoon balanced pistons ?
Old Apr 9, 2002 | 08:24 AM
pinota's Avatar
Default hp gain with Spoon balanced pistons ?
How many hp gain can i expect from the Spoon balanced pistons on my 98 ITR.
How many hours to install it ?
Thanks,
Pinota
[Modified by pinota, 5:25 PM 4/9/2002]
Old Apr 9, 2002 | 08:28 AM
sgT's Avatar
sgT
Default Re: hp gain with Spoon balanced pistons ? (pinota)
minimal at best
will take a few hours or days especially if you want to hone the walls before
installing them.
Old Apr 9, 2002 | 09:27 AM
JPP's Avatar
JPP
The general rule of thumb is 1% hp gain for every point of compression.
With the JDM/Spoon piston you should increase to 11.1:1 from 10.6:1 so you are looking at a maximum of 8 hp at around 8000 rpm (peak hp). If you decide to use them it would be a good idea to instal a thinner head gasket (2 layers) and bump the compression to 11.4:1 (while the head is removed).
Old Apr 9, 2002 | 09:29 AM
GokuSSJ4's Avatar
Default Re: hp gain with Spoon balanced pistons ? (JPP)
unless you are bumping the CR by some it will be minimal!
Old Apr 9, 2002 | 09:33 AM
sgT's Avatar
sgT
it should be more like about 2% for every point, but a point = 1.0, not 0.1
Old Apr 9, 2002 | 09:39 AM
Mike K's Avatar
Default Re: hp gain with Spoon balanced pistons ? (sgT)
You'll probably see 2hp if you're lucky.
Maybe more if you got larger cams.
Old Apr 9, 2002 | 09:44 AM
JPP's Avatar
JPP
Thank for the clarification. I was never sure what was implied by a "point" and I always assume it was 0.1 (and we all know what they say about assuming...)
Black Sheep
Sep 22, 2003 01:50 PM
DsTeg2G
Jun 20, 2003 09:07 AM
SpoonFed
Nov 3, 2001 09:15 AM
SpoonFed
Nov 2, 2001 03:59 PM
IntegraT
Oct 6, 2001 03:54 PM
