Honda S2000 Honda S2000
Lower balljoint removal/replacement
Old Apr 29, 2006 | 09:04 PM
iam7head's Avatar
Default Lower balljoint removal/replacement
Anyone know how to remove and replace the front lower ball joint?
mine is making noise when i turn the wheel when i am parking at very slow speed.
upon inspection, the boot is toasted.
the car have alot of mileages, i am thinking getting both side replaced at the sametime.
Any pointer?
what tools do i need?
thanks hT
Old Apr 29, 2006 | 09:18 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: Lower balljoint removal/replacement (iam7head)
No special tools needed, except a screw type puller to separate the arm from the joint. "Love-Taps" work, since you're replacing it you won't have to worry about the old joint's threads. The lower arm ball joint comes on a bracket, held on by 2 bolts.
http://www.hondaautomotivepart...UCKLE
You need #4.
Modified by FR-MOB: Projekt at 10:42 PM 4/29/2006
Old Apr 29, 2006 | 09:56 PM
iam7head's Avatar
Default Re: Lower balljoint removal/replacement (FR-MOB: Projekt)
excellent
thank you projekt
Old Apr 29, 2006 | 10:58 PM
* B A N N E D *
Exxxxxcellent. Now on to the whoring.
Old Apr 29, 2006 | 11:14 PM
fknfast's Avatar
just take a hammer and hit it out by the threads. 1 2 BAM out
Old Apr 30, 2006 | 09:22 AM
mykcuz's Avatar
Default Re: Lower balljoint removal/replacement (fknfast)
u could smash it with a hammer or u could get the right tool, an auto fork that u wedge in then hit with a hammer to seperate the parts.
Old Apr 30, 2006 | 09:49 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt &raquo;</TD></TR><TR><TD CLASS="quote">Exxxxxcellent. Now on to the whoring.</TD></TR></TABLE>
LOL
Old Apr 30, 2006 | 09:52 AM
* B A N N E D *
Default Re: Lower balljoint removal/replacement (FR-MOB: SnoFlake)
You know me, I'm too quick for these cats.
Old Apr 30, 2006 | 08:47 PM
fknfast's Avatar
Default Re: Lower balljoint removal/replacement (mykcuz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mykcuz &raquo;</TD></TR><TR><TD CLASS="quote">u could smash it with a hammer or u could get the right tool, an auto fork that u wedge in then hit with a hammer to seperate the parts.</TD></TR></TABLE>
its not like your re-using it
1 2 BAM
flat rate no time for shenanigans
Old May 1, 2006 | 01:24 PM
evil vapor's Avatar
Also helps to use a big hammer for those extra stubborn ball joints.
Never use a fork unless you don't care about trashing the boot.
iam7head: Check the condition of the joints first before buying new ones and replacing them. You might be able to get away with buying new boots and regreasing the joints, a common mechanical service.
Old May 1, 2006 | 02:53 PM
WowOzYouRock's Avatar
Default Re: Lower balljoint removal/replacement (vapor)
check the ***** for roundness HAHAH and discoloration
Old May 1, 2006 | 03:00 PM
SilverDc2's Avatar
Default Re: Lower balljoint removal/replacement (FR-MOB #4: Jerk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB #4: Jerk &raquo;</TD></TR><TR><TD CLASS="quote">check the ***** for roundness HAHAH and discoloration </TD></TR></TABLE>
haha,
get a big hammer since your replacing them anyways,
i made a full aluminum hammer for these types of jobs, the aluminum is softer than steel so doesn't really damage other parts, the hammer slowly is getting dinged/dented up
Old May 1, 2006 | 03:46 PM
mykcuz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor &raquo;</TD></TR><TR><TD CLASS="quote">Also helps to use a big hammer for those extra stubborn ball joints.
</TD></TR></TABLE> ive always used forks and never damaged a boot, theyre easy to squeeze together, the fork pops them right out, so borrow one from a friend, or use a hammer, and risk bending and crushing, but if u know what ur doing u could probobly just use a plastic fork and duct tape.
plus when u hit the fork on the ground it makes a much cooler noise than a hammer
oranginal
Jul 28, 2010 05:53 AM
djnikko
Jun 11, 2010 10:19 AM
munoz86
Dec 4, 2008 03:59 AM
2camsaam
Oct 2, 2003 07:30 AM
2camsaam
21
Oct 1, 2003 07:32 PM
