Rev-limiting too soon and car extra weak!!! need help
Old Apr 29, 2006 | 07:24 PM
Slowass2dr's Avatar
Default Rev-limiting too soon and car extra weak!!! need help
well i bought the car from an acution its a 1995 dx coupe 5spd. well when i bought it i couldnt open the hood but i got it open at home and it had a 1.5 dx motor but it looks like it had another motor in it before maybe a vtec because i looked at the computer and it was a p28 there where two black wires coming from it that lead to the engine conpartment but not connected to anything. at the distributer there where 4 wires that didnt look right. two of the where just hanging there not connecter to anything they were blue and they looked like they were from the harness not added and the other two were from the dizzy plug it looked like they were getting power for something not sure for what. well anyways my problem is that my car is rev-limiting at aroung 5500rpm from what i can hear (no rpm guage dx) and when it does it sounds like its choking or something it sounds horrible and the car runs really really weak its imposible to take off in second gear from a stop. i know its a dx motor and its not supposed to be fast but i had dx's before that ran way harder am pretty sure its not supossed to be like that. when i go from first to second it sounds like it goes from first to third. I was thinking it could be that i have a p28 ecu and i dont have a vtec motor or maybe those wires have to do something to do with it, am not sure i need help, what do u guys think
Old Apr 29, 2006 | 08:21 PM
EKlscoupe_98's Avatar
Default Re: Rev-limiting too soon and car extra weak!!! need help (Slowass2dr)
y would you start in 2nd gear an just try a different ecu
Old Apr 29, 2006 | 08:29 PM
Eksmashin23's Avatar
WORK ON IT AND MAKE IT FAST
Old Apr 29, 2006 | 11:16 PM
SuperSlow's Avatar
Who launches in 2nd? Monster d series powa!
Old Apr 30, 2006 | 10:14 AM
Slowass2dr's Avatar
Default Re: Rev-limiting too soon and car extra weak!!! need help (SuperSlow)
i didnt say i was launching in second gear i ment when i am at a stop sign well anyways i couldnt open the hood because the line was broken. what do u guys think about the 4 wires and is my problem the ecu. thxs
Old Apr 30, 2006 | 10:22 AM
FalkenSiR's Avatar
And of course you have a check engine light, right?
I think it might be because you are running a p28 with a non vtec motor, therefore the rpm limiter is lower because of no vtec engagement.
Old Apr 30, 2006 | 12:28 PM
Slowass2dr's Avatar
Default Re: Rev-limiting too soon and car extra weak!!! need help (fast88std)
well anyways am planning to put a vtec motor in it soon do u guys think that will fix the problem
Old Apr 30, 2006 | 12:39 PM
cambopheonix56's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slowass2dr &raquo;</TD></TR><TR><TD CLASS="quote">well anyways am planning to put a vtec motor in it soon do u guys think that will fix the problem</TD></TR></TABLE>
Yes.
Old Apr 30, 2006 | 11:52 PM
Evolution-93-Ex's Avatar
From: Your mommas bed, that might be true too ..., So Cali, USA
Default Re: Rev-limiting too soon and car extra weak!!! need help (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">And of course you have a check engine light, right?
I think it might be because you are running a p28 with a non vtec motor, therefore the rpm limiter is lower because of no vtec engagement.</TD></TR></TABLE>
Prob right run the correct ecu until you get a vtec whether it be d16 or b16
Old May 4, 2006 | 04:15 AM
Slowass2dr's Avatar
Default Re: Rev-limiting too soon and car extra weak!!! need help (Evolution-93-Ex)
am planning on putting in a b16 can i use the p28 without chipping it just for a while until i get enough to chip it or do i have to chip for it to run
Old May 4, 2006 | 04:27 AM
honda_civic1's Avatar
those 2 blues wires coming from the disturbter is for the tech(RPM). so how do you really know where your car is really redline at if you don't have a rpm gauge in it? and if you are going to drop a b16 in it then you should do everything right the first time then taking short cuts.
Old May 4, 2006 | 06:51 PM
Slowass2dr's Avatar
Default Re: (honda_civic1)
i installed a tach today and i was right it redlines at 5500, also i got the wire colors so if someone knows what they are for please let me know. there are 3 of the cus one of the was the rpm guage one. there is a cut black with a yellow stripe there is a cut blue with black stripe (not the rpm signal wire) and there is a black one, i was thinking that maybe those were the factory vtec wires cus like i said the car had some type of vtec motor in it cus it still has the vtec ecu(p28), maybe the left the vtec harness and put the old motor back. anyways let me know what u guys think.
Modified by Slowass2dr at 3:04 PM 5/8/2006
Old May 8, 2006 | 02:04 PM
Slowass2dr's Avatar
bump need help
Old May 9, 2006 | 04:08 AM
Slowass2dr's Avatar
anybody
Old May 9, 2006 | 05:13 AM
99CivicSiBrian's Avatar
B A N N E D
werd.
And I have a VTEC motor here ready to go. I'm in Lancaster PA if you want it.
Good price and guaranteed not stolen!! LEMME KNOW
B
Old May 15, 2006 | 04:15 AM
Slowass2dr's Avatar
Default Re: Rev-limiting too soon and car extra weak!!! need help (99CivicSiBrian)
what kind of vtec motor b-series? let me know
Old May 15, 2006 | 05:42 AM
tHeeeazy E's Avatar
i drive starting from 2nd gear all the time when i drive normally, but then i have an 97 Spec R motor with LSD
turb0gsr3
Sep 23, 2004 06:33 AM
crexer
Oct 11, 2003 11:49 AM
integra6650
Feb 21, 2003 02:36 PM
cyris3d
Jul 30, 2001 08:36 PM
