Damn, radiator hose gone
Old Apr 29, 2006 | 07:17 PM
Crackerballer's Avatar
Default Damn, radiator hose gone
So I drove the RS with B18C1 swap today, been driving it since yesterday. I knew when i bought it that it might need a new fan, because the old one is really starting to chatter. Well I went to a friends house today, and heard the noise, so I popped the hood.
It's a good thing I did too, because where the upper hose runs to the block was allowing coolant to leak out, and it was almost all gone. So I let it sit, went to the gym, then drove it home.
Question, should I just wait till monday and buy an OEM hose from the dealer, or get an aftermarket set like what Greddy offers? Don't really care if it's *Bling*, just want it to be reliable.
Modified by Crackerballer at 9:03 PM 4/29/2006
Modified by Crackerballer at 10:25 AM 4/30/2006
Old Apr 29, 2006 | 07:21 PM
blkb18's Avatar
Default Re: Damn, radiator hose gone (Crackerballer)
oem will always yield reliability, but it is just a hose. I personally would wait one day and go oem, but i am sure most hoses will be just fine.
Old Apr 29, 2006 | 08:46 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Even a hose from somewhere like autozone would work fine.
Old Apr 29, 2006 | 08:58 PM
ecks_fourttwo's Avatar
Default Re: Damn, radiator hose gone (FlatBlackTeg)
i got mine from auto zone and i havent had any problems with it...
Old Apr 29, 2006 | 10:35 PM
Deluzional's Avatar
Default Re: Damn, radiator hose gone (ecks_fourttwo)
i ripped a hole in my upper hose...picked one up from kragen, no problems either
Old Apr 30, 2006 | 08:57 AM
*update* Just pulled the hose off, and it doesn't seem to be cracked or split. The fluid was leaking out of where the hose slipped onto the block, so I am thinking it just wasn't on there tight. Now the questions is, do i slip it back on and try to leave the same clip to keep it secure? Do any of you guys use the clamps that you tighten with a screw driver on there, or just the ones that you take plyers and squeeze the tabs together to loosen them>
Old Apr 30, 2006 | 09:15 AM
.one lane's Avatar
.likes trains
If it's leaking from the "seal" I'd use one of those clamps that needs to be screwed to be tighten.
Old Apr 30, 2006 | 09:24 AM
Yea I am going to run to the store real quick and see if I can pick some up. It is where the hose slips on the block, it was trickeling down from the under half and was coming out pretty quickly.
kaivorth
Honda Civic (2001 - 2005)
Jul 20, 2017 12:02 AM
Cyber ITR
Jun 11, 2006 09:28 PM
jDMJeRk
Mar 1, 2005 12:28 PM
junglistgsr
Apr 1, 2003 07:23 AM
fiebru1119
Nov 1, 2002 09:49 AM
