Suspension & Brakes Theory, alignment, spring rates....
4x114.3 swap?
Old Apr 29, 2006 | 05:41 PM
ChampWhiteTegra's Avatar
Default 4x114.3 swap?
can u use anything off a prelude to do this swap or is the 96 itr the only way , please explain?
Old Apr 29, 2006 | 08:55 PM
iam7head's Avatar
Default Re: 4x114.3 swap? (ChampWhiteTegra)
itr 96 spec, you need the whole knucle, etc
Old Apr 29, 2006 | 09:31 PM
MasterKwan's Avatar
Default Re: 4x114.3 swap? (iam7head)
What are you starting with? If you have 96-2001 integra/99-2000 SI or 96-2000 Civic EX spindles, you can bolt on 91+ legend calipers and brackets and use the 4x113 Prelude rotors by re-drilling the holes. You have to trim about 0.1" off the non-machined side of the legend brake bracket.
I have this on my EK (spindle swap). Basically 4 lug R brakes. The prelude rotors are a close fit. Thus the trimming. I'm looking for 11" 4x100 rotors that are 44 mm thick (1.8") (same thickness as stock SI rotors) which would fit the the brackets without trimming.
Old Apr 30, 2006 | 08:47 AM
i have 95 dx coupe now , i just got it bone stock and i want the 96spec itr wheels so im goin to do what i have to do
b18 type r
Suspension & Brakes
Dec 1, 2010 01:59 PM
b18 type r
Dec 1, 2010 03:56 AM
DuongBros.
Suspension & Brakes
Oct 18, 2008 02:04 PM
DAchiko
Sep 9, 2007 09:11 AM
colinproctor
May 6, 2004 04:16 AM
