auto to manual??? help searched shift linkage bolts
Old Apr 29, 2006 | 05:31 PM
sycamore
Guest
Posts: n/a
Default auto to manual??? help searched shift linkage bolts
where do you bold up the bolts for the shift linkage support arm or what ever..???
Old Apr 29, 2006 | 06:17 PM
slodel's Avatar
Default Re: auto to manual??? help searched shift linkage bolts (sycamore)
r e d s e a r c h button
Old Apr 29, 2006 | 09:11 PM
sycamore
Guest
Posts: n/a
Default Re: auto to manual??? help searched shift linkage bolts (slodel)
yea i did and didnt find what im was looking for
Old Apr 29, 2006 | 09:27 PM
slodel's Avatar
i put in Auto to Manual and it came up with 324 results
Old Apr 29, 2006 | 09:32 PM
Luserkid's Avatar
Take out your center cousole and look for the area where you could drill in 2 holes, drill it out and stick the bolt there.
Old Apr 30, 2006 | 09:53 AM
sycamore
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slodel &raquo;</TD></TR><TR><TD CLASS="quote">i put in Auto to Manual and it came up with 324 results</TD></TR></TABLE>
and i looked through like 300 or them and none of them told me how to do this..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Take out your center cousole and look for the area where you could drill in 2 holes, drill it out and stick the bolt there. </TD></TR></TABLE>
thanks
Old Apr 30, 2006 | 02:02 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: auto to manual??? help searched shift linkage bolts (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Take out your center cousole and look for the area where you could drill in 2 holes, drill it out and stick the bolt there. </TD></TR></TABLE>You can actually see an "indention" where the holes were supposed to be drilled.
Old Apr 30, 2006 | 03:42 PM
ATX45's Avatar
when i did mine i did what Nvturbo sugested the indents are the perfect spot drill them out and it should line up and just use some extra bolts and nuts
Jlamar757
May 25, 2006 03:16 PM
pumpkyn
May 18, 2006 10:35 AM
BlackHXCoupe
15
Mar 4, 2006 05:40 PM
bman511
Jul 1, 2005 07:04 PM
tuner6r
15
Mar 20, 2005 09:45 PM
