SRS Light Question
My SRS light recenlty came on and won't go off. I was reading through my Civic owners manual and it states that you need to take your civic in after it is 10 years old to have the SRS system checked out. My car was exactly 10 years old when the light came on. Do you think the SRS light comes on automatically at the 10 year mark because Honda recommends the system be checked out after 10 years?
Reset it using this (instead of MES connecter use a paperclip bent into a U shape)
If it relights after that then see a specialist.
Never heard the 10 years thing before though.
i wondering if the whole srs light staying on thing a 96 and up thing becuase almost every 6th gen ive seen have that problem i never see that on 5th gen
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DANgerous »</TD></TR><TR><TD CLASS="quote">LOL! It says not to use a jumper wire right in the directions. Why is that?</TD></TR></TABLE>
So you'll take it to a Honda dealer and pay loadsa money
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DANgerous »</TD></TR><TR><TD CLASS="quote">Makes perfect sense...if you're Honda.
Now you're getting it
There is always a simple way around a complex problem
I set my SRS light as described above and it comes on for a few seconds after startup every time as it should, before going out, isn't alchemy great
</TD></TR></TABLE>Now you're getting it
Because if you jump the wrong pins then your going to have an unexpected airbag in your face.
And "macsmurray" you need to remove that picture before AHM finds it and comes after you. Reposting their info is not allowed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooGoCow3 »</TD></TR><TR><TD CLASS="quote">Because if you jump the wrong pins then your going to have an unexpected airbag in your face.
And "macsmurray" you need to remove that picture before AHM finds it and comes after you. Reposting their info is not allowed</TD></TR></TABLE>
I'll take my chances bud
I've been posting that page for the last year
Hmmmm...airbag in the face. That's not good right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DANgerous »</TD></TR><TR><TD CLASS="quote">Hmmmm...airbag in the face. That's not good right?
No it's not, but search and see how many airbags blow up in peoples faces (not many).
Follow the directions and you'll be fine (it's not difficult)
</TD></TR></TABLE>No it's not, but search and see how many airbags blow up in peoples faces (not many).
Jump the wrong pins? if there are only 2, how can you jump the wong ones?
Ive got a 99 SI with the same problem, except its not 10 years old yet. Sorry to jump in the tread with another question, but I figured it would be better than starting another one with the same issue. Its been on for the past year. I really dont care if i have an airbag, but NY safety inspectors are *****. How can I get it to go away? Sorry again for piggy-backing DANgerous.
Dangydang
Jan 25, 2003 09:30 PM
