Honda S2000 Honda S2000
My speedometer reads 0 , power steering failure, vtec wont work
Old Apr 29, 2006 | 12:34 PM
Say Hello's Avatar
Default My speedometer reads 0 , power steering failure, vtec wont work
Also check engine light came on but when I scan it...it says nothing is wrong.....
is it my ecu?
i tried resetting it the vtec comes back but goes away
Old Apr 29, 2006 | 12:58 PM
Project22a's Avatar
Default Re: My speedometer reads 0 , power steering failure, vtec wont work (Spoon AP1)
It's your vehicle speed sensor (VSS). I've had similar symptoms on my Prelude when the VSS went out on that. Should be cheap to fix, though. On my Prelude the sensor wasn't even broken, it just came loose.
Old Apr 29, 2006 | 03:52 PM
ej0513's Avatar
your ECU needs to see a certain speed to activate VTEC. so check the VSS like the previous post said.
Old Apr 30, 2006 | 12:02 AM
Mr. Projekt's Avatar
* B A N N E D *
In case you can't find it, its on the tranny, right behind the clutch slave, below the O2 sensor plugs.
Old Apr 30, 2006 | 12:27 AM
Say Hello's Avatar
Default Re: My speedometer reads 0 , power steering failure, vtec wont work (FR-MOB: Projekt)
i purchased an ap2 trans today
so leaving s2k parked unless im going to a meet and most s2k owners = dousche bags but ur cool n zo iz francesco
Old Apr 30, 2006 | 06:35 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon AP1 &raquo;</TD></TR><TR><TD CLASS="quote">so leaving s2k parked unless im going to a meet and most s2k owners = dousche bags but ur cool n zo iz francesco</TD></TR></TABLE>
aint that the truth.....
fyah2k5
Aug 25, 2014 11:19 AM
vicki
12
Oct 22, 2008 10:26 AM
ricearoni56
Feb 11, 2008 05:10 PM
686_ef
11
Apr 6, 2005 05:57 PM
Quade
Jun 10, 2003 01:55 PM
