Radiator fan dead...
Do any of yall prefer one type of radiator fan to another. I think the fan has died in my 94 lx and need to get it replaced. I was thinking of buying one off of ebay. as they seem to be just about as cheap as autozone and will cost me no tax. Any thoughts on this.
Will G.
Will G.
Is it the condeser far or the radiator fan?
Have you checked the fuse? How are you sure it's bad?
As long as you don't get a no name fan motor you can pick one fo those up pretty much anywhere. But the aftermarket ones tend to be a little noisy.
before you condemn the fan motor ,, make sure that you are getting power and ground at the fan plug,,, if you get both it is a bad motor,,
if you don't get either or, diagnose the issue before you replace the fan motor ,
No i hadn't checked the fuse for the fan. it is the rad fan. when i turn on the Ac the other fan comes on and when i turn it off it goes off. the fan taht isn't running is on the pass side of the radiator i think.
Will G.
Will G.
Hobkins
Oct 15, 2012 04:57 PM
