Installing jdm EL in US Dash
Old Apr 29, 2006 | 10:36 AM
Green Lude 93's Avatar
Default Installing jdm EL in US Dash
im considering buying the jdm EL cluster for my 93 lude. i want the km/h. I dont know if it has been done but im sure it has. Can someone help and give me guidance or a link that may contain instructions to do so?
Old Apr 29, 2006 | 11:01 AM
Prelude SIR-T's Avatar
Default Re: Installing jdm EL in US Dash (Green Lude 93)
if you search i almost bet it has been done! i know for a fact that there is a wire scheme for the change from regular to el conversion.
Old Apr 29, 2006 | 11:12 AM
Razer's Avatar
well i haven't done it and wont need too once I finish the Right hand drive swap. But I did make a wire harness for my 92 to put a JDM cluster in the US clips so it pretty much make the JDM cluster plug and play. I can give you a hand and let you know what JDM wires need to go where to work. the Invertor should just be a simple power hook up unless you hook it to the dimmer but that may all work together. I don't have an EL cluster yet but will look for one once my swap is done. (front clip got here yesterday)
Old Apr 29, 2006 | 12:18 PM
wstef's Avatar
But if you buy a JDM cluster you will still in need of USDM housing - the shape is different - the cluster is not symetrical...
Old Apr 29, 2006 | 12:28 PM
Razer's Avatar
yea, you will need to remove the front housing and a few other things. it wont fit perfect but it will go in. Wiring is not hard if you know where everything goes.
Old Apr 29, 2006 | 03:53 PM
Default Re: (Razer)
im not that worried about wiring. i curious of fitment. i know that the mounts are obviously opposite but im curious if its still possible to mount it and still be flush.
Old Apr 29, 2006 | 07:27 PM
mgags7's Avatar
hit the search button dude, this has been WELL covered recently
slvrlude
Jun 21, 2008 10:31 AM
Daniel_san
Apr 26, 2004 09:22 AM
ApexiR222
Mar 22, 2002 09:43 AM
