1993 Accord LX
My car does not beep when I leave the headlights on when I take the key out. How do I fix this. Sometimes in the morning its dark when I leave to work but when I get there its bright and sometimes I forget to check and the **** is dead when I go home. Need help. Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Perfectionist »</TD></TR><TR><TD CLASS="quote">Does the 'dome' light come on when you open the door? If not, the switch could be faulty or just dirty. </TD></TR></TABLE>
No the dome light does not come on. What switch?? Thanks for the response.
The switch is in the door post, remove the phillips screw under the 'slider' pull the switch and you can clean the contacts with some fine sand paper.
Accord-Ridgelin
Mar 28, 2017 06:17 PM
yashuvp
Jan 4, 2013 08:23 AM
