Whats the best TB and IM for z6 head?
Old Apr 29, 2006 | 06:20 AM
JDM_EK_JOE's Avatar
Default Whats the best TB and IM for z6 head?
I heard that the y8 IM has long runners and provides more air flow and the TB is 1mm wider in diameter compared to the a6 TB so I just wanna if the y8 head will fit the z6 head and also if I wanna go y8 IM and TB will I need to also use the y8 Fuel Rail and Injectors to match the head or is my a6 Fuel Rail/injectors good enough
Thanks in advance
Old Apr 29, 2006 | 06:31 AM
Soccerking3000's Avatar
Default Re: Whats the best TB and IM for z6 head? (91Civic_Joe)
the y8 manifold will fit a z6 head fine, it is known as the type-r of d-series manifolds, as for the throttle body being larger, i dont think thats true i thought all d-series were the same, i could be wrong though
Old Apr 29, 2006 | 06:35 AM
SVOboy's Avatar
Not all d series are the same, some crx era stuff is smaller, and the hf/cx/vx measure in at 40mm. I think you can get b series tbs to fit on the y8 im, but I'm not sure which and what their sizes are.
Sleepy_Red_hatch's Avatar
Default Re: (SVOboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">Not all d series are the same, some crx era stuff is smaller, and the hf/cx/vx measure in at 40mm. I think you can get b series tbs to fit on the y8 im, but I'm not sure which and what their sizes are.</TD></TR></TABLE>
perhaps i should introduce you to my d15z1 TB
Old Apr 29, 2006 | 06:40 AM
SVOboy's Avatar
I mentioned that it was 40mm, I have the same tb on my crx currently.
cmgibby
Mar 3, 2009 04:35 PM
SpdKilz23
Oct 2, 2008 09:45 PM
4ghatch
Apr 13, 2008 11:26 PM
foam
Nov 15, 2006 01:06 PM
