Need to know where the fuel pump fuse for eg6 95
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jpuno »</TD></TR><TR><TD CLASS="quote">i need to find out where the fuel pump relay is at because i lost the cover</TD></TR></TABLE>
wtf?
Ok, I'm seeing a mention of cover, relay, and fuse. What do you need?
Cover for the fuel pump is under the rear seat. Fuel pump fuse is in the fuse box. I believe it's in the under hood one, but to be honest, I'm not going outside to check. If you need the relay, the fuel pump works off the main relay, a known failure point on 92-95 civics. It's located on the driver's side of the car, under the dash.
wtf?
m.glisson003
Oct 31, 2011 05:53 PM
CrX-To-Tha-Max-v2.0
22
May 4, 2005 10:07 PM
