99 b16a2 into a 97 civic wiring nightmare (please help)
Old Apr 28, 2006 | 11:02 PM
EJtypeR's Avatar
Default 99 b16a2 into a 97 civic wiring nightmare (please help)
the main problem im having is the si wire harness only has 2 plugs (B,C)for the ecu. because the first(A) ecu plug is a part of the car on a si. so what would be the easiest way about doing this. i want to get this bitch b.a.r. legal.
1. get a 99 ex wire harness and adapt it to the b-series
2. wire the A plug into the car
3. get all the wiring from the si
4. shoot myslef in the head
5. shoot the guy i bought the motor from
6. fu*k it
Old Apr 29, 2006 | 01:12 PM
devilduck's Avatar
Default Re: 99 b16a2 into a 97 civic wiring nightmare (EJtypeR)
I am having the same problem, and that is the 99-00 SI harness has two parts the interior and extrior harness. So if when you got the harness for the engine you did not get the one for the interior it is almost impossible to make the engine work with all your stuff. The simplest fix, what I did, was get a harness that matches the model that you need. So if you have a 97 then you need to get a 97 harness and adapt it to work with VTEC.
Old Apr 29, 2006 | 02:27 PM
EJtypeR's Avatar
Default Re: 99 b16a2 into a 97 civic wiring nightmare (devilduck)
so how do i get it smogged? and what ecu did you use? i went looking at harnesses and they are all the same for ex from 96-00 its gay honda really fu*ked up this one...
Old Apr 29, 2006 | 04:23 PM
EJtypeR's Avatar
come-on its not like this is an un common swap...
Old Apr 29, 2006 | 06:57 PM
devilduck's Avatar
Yeah, if you get an EX harness it will work right. Just get rid of the SI harness, or sell it on EBAY, then you will be able to use the B16 ECU. That is what I am using for my swap, until I can save up and get AEM EMS.
Old Apr 29, 2006 | 08:37 PM
EJtypeR's Avatar
what year ex harness, i went to H-auto and looked at all of thier harnesses for 96-00 and they were all the same OBD2a i couldnt find a OBD2b unless thier **** was marked wrong...
Old Apr 29, 2006 | 09:24 PM
k24a4kid's Avatar
I'm a Jackass
yes you need a ex harness.. 96-98 obd2a, 99-00 obd2b
hope that helps
Old Apr 30, 2006 | 05:53 PM
TspEk9's Avatar
use ur old 96-98 civic harness, get obd2a-obd1 conersion harness and run p28. this will leave u more option for chipping, f/i
Old Apr 30, 2006 | 06:14 PM
k24a4kid's Avatar
I'm a Jackass
Default Re: (TspEk9)
yup i got a 96-98 conversion harness
Old May 1, 2006 | 08:10 PM
EJtypeR's Avatar
Default Re: (k24a4kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TspEk9 &raquo;</TD></TR><TR><TD CLASS="quote">use ur old 96-98 civic harness, get obd2a-obd1 conersion harness and run p28. this will leave u more option for chipping, f/i</TD></TR></TABLE>
i got the car running today. i took the harness off of my ITR motor and ran a p73. its good and all untill smog time...
Old May 8, 2006 | 03:51 PM
TspEk9's Avatar
good ****
Old May 10, 2006 | 05:39 AM
Trey's Avatar
25 Year Member
If you have a 96-98 ek, then you need an 96-98 EX harness and 96-98 ECU. If you have a 99-00 Ek then you need a 99-00 Si/ EX harness and 99-00 ECU. This is if you want all the Vtec stuff there.
You can reuse yoru CX/ DX harness and add what you need as well.
All the info you need on the swap is just a click away, check my sig.
Old May 10, 2006 | 05:40 AM
Trey's Avatar
25 Year Member
Default Re: (EJtypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJTypeR &raquo;</TD></TR><TR><TD CLASS="quote"> got the car running today. i took the harness off of my ITR motor and ran a p73. its good and all untill smog time... </TD></TR></TABLE>
WTF? The teg harness is two piece and the Ek Civic harnes is one piece??
Old May 20, 2006 | 01:16 PM
EJtypeR's Avatar
Default Re: (Trey)
i took my o.g. ek 97 harness and addapted it to work with my itr motor 96, that was previously in the car...and i just got a eg hatch that i wanted to put my itr motor in. so i bought a 99 b16 for my ek. so now im up **** creek with out a harness...get it? i have a si ecu which is obd2b and plug A is apart of the car on the 99-00 si and the harness i have is obd2b missing plug A. but the harnes im using now is off of my itr which is obd2a....with a p73
Outlaw-Hondaz
14
Jul 7, 2010 02:18 PM
eeyore357
Jul 5, 2005 10:52 PM
DirtyDawg21
10
May 1, 2004 07:44 AM
esoterEK..
Jan 21, 2004 12:16 AM
Unknown Member
Mar 25, 2003 06:53 PM
