225/45R16 on ITR? any experience?
Old Apr 28, 2006 | 10:11 PM
powersteer's Avatar
Default 225/45R16 on ITR? any experience?
Hi fellow drivers,
I have problems getting 215/45R16 in my area. Have anyone of u had experience running 225 tyres on JDM 16" wheels? Have u encountered any rubbings?
Looking at 225/45R16 from AD07
Have u guys came across any other good tyres that is available in 215/45R16 or 225/45R16?
*tried doing a search but returned nothing relevant*
Old Apr 29, 2006 | 09:51 AM
powersteer's Avatar
Default Re: 225/45R16 on ITR? any experience? (powersteer)
anyone?
Old Apr 30, 2006 | 02:22 AM
ahfung's Avatar
225/45/16 depending on how low u r going should be fine. But your fenders should be rolled if you're playing with these sizes considering that u have lowered your car. All depends on the offset of your wheels and the height of your ride.
Old Apr 30, 2006 | 05:23 AM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powersteer &raquo;</TD></TR><TR><TD CLASS="quote">
I have problems getting 215/45R16 in my area. </TD></TR></TABLE>
http://www.vulcantire.com &lt;--Azenis RT615 at a good price in 215-45-16.
I'd go for that before I went to 225-45. Your speedo will be slightly off, and you'll be travelling at a speed slightly faster than your speedo says. Knowing how most of you hot shoes drive, anyway, I wouldn't want to see you getting a ticket because you're already used to pushing the envelope.
I've seen 225-50-16 on a roadgoing K motor ITR just so he could keep the speedo accurate, and it worked fine on Spoon +45 wheels. So I'd think you're probably be OK w/225's on your JDM +55 wheels if you are at normal ride height.
Old May 1, 2006 | 05:15 AM
powersteer's Avatar
anyone else here running it?
Old May 1, 2006 | 05:39 AM
migs's Avatar
Default Re: (powersteer)
I know thats what the Spoon car ran. I dont think you will have any problems using it as long as you have adjustable camber arms.
Old May 1, 2006 | 02:45 PM
nsxtasy's Avatar
H-T Order of Merit
225/45-16 is too big and will probably rub.
As noted above, 215/45-16 is available for the Falken Azenis RT-615. If you want a supersticky tire that grips like a sonofabitch on dry pavement, that's the one to get.
If you would prefer to trade off some dry traction for much longer treadlife and better wet traction, another tire available in that size is the Dunlop Direzza DZ101. It's a budget performance tire, similar to the Yokohama ES100, Kumho SPT, etc.
Lots of tires are available in 205/45-16 which will also work on the ITR just fine. Tires available in that size, and best for the price, include the Goodyear F1 GS-D3 (excellent dry traction, outstanding wet traction, excellent treadlife, somewhat expensive but worth it) and the Kumho Ecsta SPT (very good dry traction, excellent wet traction, excellent treadlife, at a great price).
Old May 1, 2006 | 04:13 PM
Black R's Avatar
25 Year Member
Default Re: 225/45R16 on ITR? any experience? (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">http://www.vulcantire.com &lt;--Azenis RT615 at a good price in 215-45-16.
I've seen 225-50-16 on a roadgoing K motor ITR just so he could keep the speedo accurate, and it worked fine on Spoon +45 wheels. So I'd think you're probably be OK w/225's on your JDM +55 wheels if you are at normal ride height.</TD></TR></TABLE>
.....what about a 225/40/16?
http://www.edgeracing.com has some good prices on these:
http://edgeracing.com/tires/2254016/
Old May 1, 2006 | 06:34 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 225/45R16 on ITR? any experience? (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">.....what about a 225/40/16?</TD></TR></TABLE>
The outer diameter is 1.5 percent smaller than stock, and any other 225/40-16 won't stick as well as the 215/45-16 Azenis. I wouldn't...
Old May 1, 2006 | 10:18 PM
SoCal ITR's Avatar
Default Re: 225/45R16 on ITR? any experience? (nsxtasy)
225/45 16 on JDM 16's will rub at full lock on a stock ITR.
Old May 2, 2006 | 12:58 AM
powersteer's Avatar
Default Re: 225/45R16 on ITR? any experience? (SoCal ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCal ITR &raquo;</TD></TR><TR><TD CLASS="quote">225/45 16 on JDM 16's will rub at full lock on a stock ITR.</TD></TR></TABLE>
is that a personal experience?
Old May 2, 2006 | 02:20 AM
ahfung's Avatar
wok the expletive!!!.......215/45/16 is available for RT615?!!!!!!!
expletive....i checked ALL catalgues 2 months ago...for the right size in 16" and the ONLY size i found from RT615 was 205/40/16
expletive!
Old May 2, 2006 | 04:44 AM
H-T Order of Merit
Default Re: (ahfung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahfung &raquo;</TD></TR><TR><TD CLASS="quote">wok the expletive!!!.......215/45/16 is available for RT615?!!!!!!!</TD></TR></TABLE>
Yes, it is, now. The DC2 ITR owners were directly responsible for it, too.
Old May 2, 2006 | 04:45 AM
H-T Order of Merit
is that a personal experience?</TD></TR></TABLE>
He's not a dummy. He generally wouldn't say anything unless he was sure.
Old May 2, 2006 | 05:56 AM
nsxtasy's Avatar
H-T Order of Merit
expletive....i checked ALL catalgues 2 months ago...for the right size in 16" and the ONLY size i found from RT615 was 205/40/16</TD></TR></TABLE>
I believe that size became available in March. Someone posted here about getting them, a few weeks before Vulcan's website said so.
Vulcan shows the release dates for upcoming size introductions. Ever since the RT-615 was introduced, it said that they would be available (I forget whether it originally said first quarter or second quarter of this year).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">Yes, it is, now. The DC2 ITR owners were directly responsible for it, too.</TD></TR></TABLE>
How so? Vulcan planned to make it available early on. One would assume they already knew how many they were selling of the old RT-215 in that size. 215/45-16 is the 16" size normally used by those with all Integras (not just the ITR) as well as '96-00 Civics, so we ITR owners are not the only ones using it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">He's not a dummy. He generally wouldn't say anything unless he was sure.</TD></TR></TABLE>
Are you sure about that?
(Sorry, couldn't resist...)
Old May 2, 2006 | 06:30 AM
H-T Order of Merit
Default Re: (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">How so? Vulcan planned to make it available early on. </TD></TR></TABLE>
Well, they had to get Falken to make it, first. You'd think it would be common sense to make Toyo RA1 in 225-45-15, too, but it wasn't. It took a campaign before they made the molds.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">One would assume they already knew how many they were selling of the old RT-215 in that size. 215/45-16 is the 16" size normally used by those with all Integras (not just the ITR) as well as '96-00 Civics, so we ITR owners are not the only ones using it.</TD></TR></TABLE>
I'm just relaying what they've said themselves.
Old May 2, 2006 | 09:06 AM
Big Phat R's Avatar
They fit really well.
And they handle well too. I've used this tire size on my R for 4 years now. No rubbing. Great handling.
Biggest problem is finding tires in that size.
BPR - who is getting 215/45-15 A048Rs next
Old May 2, 2006 | 09:27 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 225/45R16 on ITR? any experience? (Big Phat R)
Old May 2, 2006 | 10:00 AM
SoCal ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powersteer &raquo;</TD></TR><TR><TD CLASS="quote">is that a personal experience?</TD></TR></TABLE>
Yes.
Thanks GK.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure about that?</TD></TR></TABLE>
Baggy Spandex
Jul 26, 2014 06:27 PM
JjuuN R
Jul 4, 2007 04:08 PM
Edward
May 27, 2005 06:12 AM
Black R
Mar 3, 2005 02:55 PM
01PYTypeR#1140
Feb 17, 2004 04:27 AM
