215 or 205 with eibachs?
Old Apr 28, 2006 | 09:37 PM
Dgilmour's Avatar
Default 215 or 205 with eibachs?
I will hopefully be placing an order on monday for a set of 16" rota grids and tires so I need to double check this: Will a 215/45/16 tire rub on my 2000 gs with eibach prokit springs and illumina shocks (1.3" drop)? Stock wheel is +45 offset, new wheel is +40. stock tire is 195/55/15. Wanted to go with a 205/45/16 but the Azenis don't come in that size.
Old Apr 28, 2006 | 10:13 PM
StrokeDC2's Avatar
Default Re: 215 or 205 with eibachs? (Dgilmour)
205/50/16 would be the perfect fit for you anything bigger will slightly or even more rub..
Old Apr 29, 2006 | 05:53 AM
Dgilmour's Avatar
Default Re: 215 or 205 with eibachs? (StrokeDC2)
The 205/50/16 diameter is a little too big, 205/45/16 would be perfect for the car but I want to find out if I can get away with 215's
Old Apr 29, 2006 | 08:04 AM
Solscud007's Avatar
hmm not sure. I dont think so. I have 17x7.5 rims and i run 215/40/17 and they kinda rub when i corner hard. the outer corners rub in the rear. Ihave 205/40/17 in the front.
so with a 215/40/16 it would be smaler than what im running and I have the eibach prokit too.
here is my car.
Old Apr 29, 2006 | 08:37 AM
Dgilmour's Avatar
Default Re: 215 or 205 with eibachs? (Solscud007)
Beautiful car man, I love the Volk rims too, that's why I'm getting the Rota replicas! Yea from what I'm getting from people, it's going to be close. I think I could probably get away with the 215 Azenis but I might just go with a 205/45/16 tire. Do you have any reccomendations besides the Azenis because they don't run that size?
Old Apr 29, 2006 | 10:07 AM
cjohnson_2's Avatar
I have the same suspension setup as you as well as having 16" rota grids. I am running on some Yoko AVS es100's. 205/45/16 never had any issues. Ive herd 215's will rub a little.
Old Apr 29, 2006 | 10:22 AM
mpham529's Avatar
Default Re: 215 or 205 with eibachs? (cjohnson_2)
is there a reason why wou are considering 215 series? im not trying to be dick or anything, but a lot of people just want wider tires because they think it will make them handle better or give them more traction.
Old Apr 29, 2006 | 10:29 AM
Dgilmour's Avatar
Default Re: 215 or 205 with eibachs? (Everybody Hates Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Everybody Hates Chris &raquo;</TD></TR><TR><TD CLASS="quote">is there a reason why wou are considering 215 series? im not trying to be dick or anything, but a lot of people just want wider tires because they think it will make them handle better or give them more traction.</TD></TR></TABLE>
Because I want the Azenis, but they don't make a 205/45/16 tire. (mentioned above)
Thinking now about maybe going with the Hankook rs2. your thoughts?
Old Apr 29, 2006 | 10:31 AM
mpham529's Avatar
Rs2s are more for track use. id only get rs2's for the track and not daily
id stick to something a lil more on the cheap side... es100's or azenis. lol.
i have azenis rt615 on my car. i have to admit that i do take crazy turns somtimes. but these tires wont last that long.. i think about 7-10k miles and they are out..
Old Apr 29, 2006 | 03:49 PM
Rtistik.'s Avatar
get 205/45 es100's....i love mine
ITB
Oct 31, 2005 06:02 PM
aznwash3wboi
Sep 12, 2005 01:12 AM
sibicguy
Sep 25, 2003 02:22 PM
02 coupe
16
Aug 27, 2002 03:12 PM
GSRaCeRbOI
Jan 17, 2002 07:03 PM
