just finished my mpfi swap and....
my car bogs when i get it at full throttle. I just finished doing the dx to si dpfi/mpfi. Car runs great you cant just accelerate all the way because it boggs. You can put the pedal about 3/4 of the way down and its fine, only when you floor it, it boggs. HELP GUYS. I know plenty of you have already done it, help me out fast!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sixty-seven point six »</TD></TR><TR><TD CLASS="quote">Did you switch your two outside tps wires? IT maybe reading wrong. </TD></TR></TABLE>
You gotta do that man, good point! Not the middle wire, just the outer two - switch 'em around.
Are you kickin any codes. Also did you replace the intake manifold gasket and if you did did is seal up good you might be getting a bit of antifreeze into your cylinders. Check the tps thing as well it might need to be ajusted.
same thing happend to me.. ended up being my distributor was bad.. i hope thats not whats wrong with yours and if it is i hope you can find a used one cuz new ones go for like 400
I already switch the two wires on the tps sensor. Possibly it could be the distibutor, the distributor's coil wasn't good so i put in a new coil. Would that still be the problem? Also i'll check on that manifold gasket, could be a possibility.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n »</TD></TR><TR><TD CLASS="quote">same thing happend to me.. ended up being my distributor was bad.. i hope thats not whats wrong with yours and if it is i hope you can find a used one cuz new ones go for like 400</TD></TR></TABLE>
just got a new one about 2 months ago for around 189 or somethin like that.
Chewy Built !
Aug 25, 2006 04:19 PM
cokinut
Jul 18, 2004 05:29 PM
