ran my car tonight, dissapointing time slip.
Old Apr 28, 2006 | 07:41 PM
chadmasterc's Avatar
Default ran my car tonight, dissapointing time slip.
Ran my car tonight at crapital raceway in MD. Due to it being way overcrowded i only got one run in. Here is the timeslip:
R/t .788
60' 2.606
330 6.565
1/8 9.773 mph 77.26
1000 12.502
1/4 14.828 mph 96.8
Car is a 91 dx hatch, full interior.
engine specs:
97' jdm type r bottom end
mugen head gasket
1st gen b16 head
AEBS intake manifold and type R throttle body
Buddy club spec 3+ cams
Omni valvesprings and retainers
ANR compact header
intake/exhaust
j1 cable tranny(non lsd)
yokahama evs 100 tires at 26 psi
Dynoed at 181whp (before the intake manifold, cold air intake and throttle body)running on neptune.
I was hoping to get into the 13's, Do you guys think it is possible?
Modified by chadmasterc at 5:59 AM 4/29/2006
Old Apr 28, 2006 | 07:43 PM
JL's Avatar
JL
Default Re: ran my car tonight, dissapointing time slip. (chadmasterc)
was it your first time ever on the track? just keep practicing.. go earlier in the day
Old Apr 28, 2006 | 08:00 PM
AllMotorRandy's Avatar
slicks and a little bit more practice with that motor will get you very close 13's
Old Apr 28, 2006 | 08:17 PM
RaceProfessor's Avatar
Seems a bit unusual. Your mph seems low. Our old street stock CRX went 12.90's @ 107 with 184whp weighing around 2200lbs. Make sure your car is running up to par. The reason you're running 14.80's is because of your 2.6 60' ft. If you can't get a hold of a set of slicks or drag radials, at least try running a little bit less tire pressure like 20psi.
Old Apr 29, 2006 | 01:59 AM
Default Re: ran my car tonight, dissapointing time slip. (RaceProfessor)
yeah i had a really bad launch and spun all of first gear, i think im going to try and get a set of drag radials for next time.
I thought the mph was low too because I ran 14.8 at 93mph with my b16 last year.
I definetly need to practice more, i was hoping to get more than one run in but the track was packed.
Old Apr 29, 2006 | 03:51 AM
Teamdiesel's Avatar
I have a JDM ITR, and I ran 14.1@98 mph on snow tires, with a 2.4 60'. The car has a Rage header and a clutch kit, everything else is basically stock, and this was done with the diver's side mount totally gone.
Old Apr 29, 2006 | 07:31 AM
97mini-me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chadmasterc &raquo;</TD></TR><TR><TD CLASS="quote">Ran my car tonight at crapital raceway in MD. Due to it being way overcrowded i only got one run in. Here is the timeslip:
R/t .788
60' 2.606
330 6.565
1/8 9.773 mph 77.26
1000 12.502
1/4 14.828 mph 96.8
engine specs:
mugen head gasket
1st gen b16 head
ANR compact header
intake/exhaust
Right there is your problem.... You should be able to pull at least a 2.1 See my sig for comparison. That was a 2.1 60' in a heavier car. 13's shouldn't be a problem. Just practice. I dropped my time by .7 just by practicing, no new mods added. Try adjusting tire pressure too. Good luck.
Old Apr 30, 2006 | 03:28 AM
22boost's Avatar
capital sucked friday. waited two hours for my first pass on my car i went a 15.0 at 99mph. two hours later second pass i went a 14.1 at 100mph. h22 eg w/ bfg g-force street radials. first pass i spun all through first, and damn near all the way through second. -staged around 3.5k my second pass i staged lower 2.5k and eased out the hole, didn't spin as bad in first and second hooked up a lot better. im trying to get some slicks, i would be suprised if i was able to pick up a low 13 with slick and practice. capital isn't the best place in the world the track sucks. since 75/80 everyone came to capital.
Old Apr 30, 2006 | 06:28 AM
nsxmatt's Avatar
Can't really judge the performance of a car with one bad run, just go back and try again on a better day.
Old Apr 30, 2006 | 03:02 PM
Default Re: (nsxmatt)
thanks for all the comments guys, im going to try and get to the track again asap and see what i can do.
Old Apr 30, 2006 | 05:55 PM
red cx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">Can't really judge the performance of a car with one bad run, just go back and try again on a better day.</TD></TR></TABLE>
practice practice practice. 99% of drag racers are always dissapointed in the times they run. If your car went lets say 7 flat, You will go home lay in bed and say to yourself " I know this car's got 6:99 in it I know it.
Old May 1, 2006 | 09:21 AM
stockcolt's Avatar
u have a 2.6 60ft........
Old May 1, 2006 | 04:38 PM
22boost's Avatar
Default Re: (chadmasterc)
im planning on going up there friday but real early. might get my **** trailered up there with my friends truck/trailer, thats another 30hp and im trying to get bfg's tomorrow hopefully slicks by NOPI at MIR
Old May 1, 2006 | 06:21 PM
Used2beAb16's Avatar
Default Re: (93dxkid)
just gotta lower the 60 ft by alot and u will be pleased. get soem 22 inch slicks
Old May 2, 2006 | 02:28 PM
Default Re: (Used2beAb16)
I plan on getting drag radials, are bfg's the best? they seem to be the most popular.
I would get slicks but i do not want to break my axles(stock integra axles).
Old May 2, 2006 | 04:09 PM
22boost's Avatar
i have heard that drag radials are harder on axles then slicks because it is a harder compound then a soft slick...however i have read that a lot of people are making a lot of power and using stock axles...not breaking them by preloading them at the launch. im picking up some bfg drag radials friday and will be running them at capitol if weather permits ...im going to be trying BFG 215x50x15
Old May 15, 2006 | 06:25 PM
ok i ran on friday and did a little better. I got there at 4:30 and got in 9 runs. Here is the timeslip from my best run.
R/T .859
60' 2.225
330 6.120
1/8 9.303
mph 77.05
1000 12.024
1/4 14.345
mph 97.43
I was hoping to get into the 13's with this setup but i guess ill be content. Im going to go again but i doubt ill get anything better than 14.2
Old May 15, 2006 | 07:13 PM
1 2 NV's Avatar
your car is not tuned period. my friends car with a B16 and bolt ons runs faster traps than that.
Old May 15, 2006 | 07:30 PM
Default Re: (1 2 NV)
well it was tuned perfectly by jeff evans, then i upgraded to type R throttle body, aebs manifold, and cold air intake. previously i had obd0 b16 tb/manifold and a cheap short ram.
so maybe thats why its trapping low.
Old May 15, 2006 | 07:32 PM
1 2 NV's Avatar
thats odd, evens is a good tuner. i dunno what to tell you man, traps are low though. i ran mid 14s in a 99 EX with GSR motor, DC 4-2-1 header, intake and ITR cams.
Old May 16, 2006 | 01:59 AM
22boost's Avatar
R/T .859
60' 2.225
330 6.120
1/8 9.303
mph 77.05
1000 12.024
1/4 14.345
mph 97.43
I was hoping to get into the 13's with this setup but i guess ill be content. Im going to go again but i doubt ill get anything better than 14.2</TD></TR></TABLE>
If your were running on radials i would think you could atleast get a 2.0 60'. That would net you closer to 13's. Work your your 60's and launching and you will get where you want to be.
my best was a 14.1 at 100mph on 205x50x15 bfg street radials. I put on some 225x50x15 bfg drag radials and went 13.89 @ 99.7 mph the first pass...that was with not being able to really do a burn out because of emergency brake issues. my 60' went from a 2.2 to a 2.0.
Myxalplyx
Honda Fit
Nov 19, 2014 09:34 PM
bOOsTiNSoHcVtEc
Mar 16, 2004 11:51 PM
Tru_Hybrid
Oct 12, 2003 08:51 PM
Hondasaurs
Jul 4, 2003 11:42 AM
VTEC-DA
Jul 28, 2002 08:29 PM
