removing your ebrake cables on your ek?
anybody have experience removing your stock ebrake cables on your ek hatch?? what did you need to do?? what was included in removing them?? any help is appreciated it!
sorry didnt search as i was in a hurry.
thanks in advance!
thanks in advance!
-First you should disconnect the cables from each caliper. This is simple & self explanitory by looking at them.
-Next remove the e-brake cover.
-Now disconnec the cables from the e-brake lever (self explanitory).
-Get under the car & disconnect all the bolts that hold down each cable.
-next remove a the bolts that couple the rear exhaust section from the cat.
-now remove the heat sheild that located above the exhaust (under the e-brake handle).
-pull the cable grommets out of their holes from underneath the car.
-pull the cables through the holes in the floorboard (where the grommets were).
-pull entire cable through trailing arm towards the back & remove from car.
-open beer
-enjoy
-open beer
-enjoy
93civicsedan
Jul 7, 2016 12:17 AM
