RSX type s RSX type R brakes?????
Old Apr 28, 2006 | 03:16 PM
fourdoorturbo's Avatar
Default RSX type s RSX type R brakes?????
I looking to find out if the rotors on a jdm dc5 type r with the brembo brakes are the same size as the usdm dc5 type s. I want to know cause i want to put the brembo calipers on my type s but i don't know if there is a difference, besides the bigger caliper. Bad part is I already bought new brakes all around before I thought of getting the type r suspension setup.
Old Apr 28, 2006 | 03:20 PM
silver j's Avatar
https://honda-tech.com/zeroforum/32
Old Apr 28, 2006 | 03:31 PM
Mugen Mike's Avatar
Default Re: RSX type s RSX type R brakes????? (fourdoorturbo)
Try the RSX forum, as linked in the post above mine.
Old Apr 29, 2006 | 07:37 AM
RyCeRoCkeTz's Avatar
just wondering, is it possible for the DC5 R brembo brakes or calipers to be swapped on an ITR?
Old Apr 29, 2006 | 11:42 PM
itr1244's Avatar
Default Re: RSX type s RSX type R brakes????? (RyCeRoCkeTz)
nothing is impossible
Old Apr 30, 2006 | 01:19 AM
Circuit Star-29's Avatar
Default Re: RSX type s RSX type R brakes????? (itr1244)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">nothing is impossible</TD></TR></TABLE>
Mostly true...I wouldn't waste anytime trying to convert a DC5R brembo caliper to a DC2R knuckle...
Old Apr 30, 2006 | 06:52 PM
BarracksSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourdoorturbo &raquo;</TD></TR><TR><TD CLASS="quote">I looking to find out if the rotors on a jdm dc5 type r with the brembo brakes are the same size as the usdm dc5 type s. I want to know cause i want to put the brembo calipers on my type s but i don't know if there is a difference, besides the bigger caliper. Bad part is I already bought new brakes all around before I thought of getting the type r suspension setup.</TD></TR></TABLE>
Nope, the JDM ITR Brembos aren't the same size -- they're bigger. Their calipers are also bigger than stock (of course), and to account for their increased width, the offset is larger -- the ITR wheels have a +60 mm offset. Plus, the pads cover a larger area, not only all the way to the outside of the rotor but also nearly all the way in towards the center, too.
The rear brakes are effectively the same as stock, but the hub/brake hat is similarly taller to use the +60 offset wheels.
Old May 1, 2006 | 01:59 PM
Default Re: RSX type s RSX type R brakes????? (BarracksSi)
I'm going to get the type r wheels so thats really an issue anymore, but would you happen to have measurement i could compare stock to the brembo i know the stock discs are 11.8".
Old May 1, 2006 | 07:44 PM
BarracksSi's Avatar
I don't remember the measurement -- maybe 12.5"? I mentioned the larger pad area as well, so the rotors end up with quite a bit more brake swept area than the stock type-s brakes.
If I see the number elsewhere, I'll try to remember to post it up here.
xiongtoua1990
Apr 12, 2009 11:02 PM
Mflyn002
Mar 25, 2007 04:50 PM
type s o yes
Honda Civic (2001 - 2005)
Nov 20, 2006 04:18 PM
fourdoorturbo
May 1, 2006 02:45 PM
Halo
Oct 17, 2004 10:48 PM
