EG Front Swaybar & H brace ?s
Old Apr 28, 2006 | 02:27 PM
broketuner-Sol_Si's Avatar
Default EG Front Swaybar & H brace ?s
Ok, So now that I finally have a free weekend I'll install my suspension techniques front swaybar and NRG "h" brace. I was wondering if there is anything I should know in advance that might cause problems (ie: take longer to get done). Also any idea how long this should take? If anyomnes interested I can take pics and make a how to.
Old Apr 28, 2006 | 02:48 PM
Voyage34's Avatar
Default Re: EG Front Swaybar & H brace ?s (broketuner-egb16a)
the swaybar is pretty straightforward, at least it was on my 96.
the only issue since im still on an auto tranny, was trying to maneuver it around the wire running to the trans. after i figured out what way to twist everything it was easy.
that and watch out for seized bolts on either the brackets or header, i started to round off the corners of one of my header/cat bolts before it finally busted loose
Old Apr 28, 2006 | 07:33 PM
Default Re: EG Front Swaybar & H brace ?s (Voyage34)
Luckily I've got a manual, so not too many wires(if any) to deal with. So other than removing the header it should be fairly easy?
Old Apr 28, 2006 | 09:06 PM
sol2hatch's Avatar
when i did my GSR sway on my hatch, i didnt have to remove the header. I just seperated the cat from the header, and it squeezed between.
Old Apr 28, 2006 | 09:34 PM
Default Re: EG Front Swaybar & H brace ?s (sol2hatch)
good tip. I'll try that first
Old Apr 29, 2006 | 09:20 AM
Voyage34's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sol2hatch &raquo;</TD></TR><TR><TD CLASS="quote"> I just seperated the cat from the header, and it squeezed between. </TD></TR></TABLE>
easiest way.
Old Apr 29, 2006 | 10:28 AM
dohcVTECeg2's Avatar
post some uncarriage pics of how it looks once you are done
Dahl Sol
Nov 30, 2009 01:51 PM
chevellion
Jan 14, 2008 10:00 AM
MugenHonda
Apr 21, 2006 03:53 PM
ath94civic
Jun 10, 2004 01:29 PM
subtleluck
May 31, 2003 01:20 PM
