HELP!!! Engine throwing a o2 sensor code???
Old Apr 28, 2006 | 01:36 PM
micr0m0nk's Avatar
Default HELP!!! Engine throwing a o2 sensor code???
My engine throws a o2 sensor code...I replaced the o2 sensor with a new one and the check engine light still comes on after I start the car, I also check to see if it was still throwing the same code and it was...what do I do????
Old Apr 28, 2006 | 02:23 PM
EFin' Kyle's Avatar
Default Re: HELP!!! Engine throwing a o2 sensor code??? (micr0m0nk)
reset the ECU?
Old Apr 28, 2006 | 02:52 PM
rainforest's Avatar
Default Re: HELP!!! Engine throwing a o2 sensor code??? (H4 Project)
pull the 7.5 amp back up fuse. you will have to reset the radio after. so if you have a anti theft radio make sure to get the code. if you pull the - battery cable make sure to let the car idle for 15 mins with no a/c on to learn idle.
Modified by rainforest at 7:23 PM 4/28/2006
Old Apr 28, 2006 | 04:58 PM
micr0m0nk's Avatar
Default Re: HELP!!! Engine throwing a o2 sensor code??? (rainforest)
I have already done all the above and still the check engine light comes on???
Old Apr 28, 2006 | 08:58 PM
EFin' Kyle's Avatar
short in the wire? if u disconnect the battery for awhile and reconnect it and let it idle it should be fine that is the only thing i can think of
Old May 1, 2006 | 02:07 PM
visionOFsadness's Avatar
well if all the wiring is good and the sensor is good open the ecu up and see if any of the drivers are burnt
John3
Nov 13, 2017 11:43 AM
scspeed
Jan 27, 2010 06:33 PM
greyejcoupe
Oct 3, 2009 10:48 AM
bumthology
Oct 5, 2004 03:18 PM
EGbeater
Dec 17, 2003 07:02 PM
