310 injectors on a b16?
Old Apr 28, 2006 | 12:53 PM
1crazysir's Avatar
Default 310 injectors on a b16?
I've got a b16, skunk2 s2's pnp head ctr pitons walbro pump fuel rail etc..
I just need to know what psi to run the 310's until i get it tuned.
thanx in advance.
Old Apr 28, 2006 | 02:13 PM
onepoint6i's Avatar
Default Re: 310 injectors on a b16? (1crazysir)
just run them @ stock pressure until the tune...
Old Apr 28, 2006 | 08:21 PM
Brick Top's Avatar
just don't be hammering on it until u know your air/fuel.
check ur plugs.
Old Apr 28, 2006 | 08:59 PM
postman's Avatar
if you have a wide band, just ride around the block and adjsut accordingly
Old Apr 29, 2006 | 12:19 AM
b19coupe's Avatar
Default Re: 310 injectors on a b16? (onepoint6i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepoint6i &raquo;</TD></TR><TR><TD CLASS="quote">just run them @ stock pressure until the tune...</TD></TR></TABLE>
Old Apr 29, 2006 | 05:04 PM
Ruben19's Avatar
stock pressure
37psi and 46psi with the vaccum line off
Old May 1, 2006 | 08:41 AM
1crazysir's Avatar
well i just drove the with the 310's and it's not responsive.
I have the psi at 40 just to be safe and there is some popping from the exhaust at
idle and when i let off the throttle, if i put the fuel any higher or lower it doesn't idle right. any suggestions?
Old May 1, 2006 | 08:35 PM
Top Ramen's Avatar
Default Re: (1crazysir)
If you don't have a wideband O2, just read the plugs. If you don't know how to do that, just ask any old domestic guy.
Frozen E
Jun 30, 2007 09:43 AM
clemsoncb7
Dec 18, 2006 08:46 PM
bleedblue94
Oct 29, 2004 06:34 PM
slimcivic95
Oct 28, 2004 11:41 AM
johnzm
Sep 18, 2004 04:49 PM
