car won't start
every once in a while after i shut my car off it work start up again. after about 5 mins it start right up no probs . anyone know what could be the cost of this?. my gf said that when she had one back in 93 hers did the same thing. please help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joeny12985 »</TD></TR><TR><TD CLASS="quote">how do i check if it's bad?
You could check a diagram and check for power coming out when the key is on...Or much easier- you feel for it, when you turn the ignition switch to on you should feel it/or even hear it click on then off until you crank the engine over, if you do not feel it click...bang on it with a screw driver or something solid, it should click on after a bit.....
jimmysteezen757
10
Jan 2, 2012 05:50 PM
