Valve Lash Adjustment specs
You really need to read more carefully. It says in the writeup what to use. I just re read the whole thing to make sure and it was there.
Rushing your work or your research will only lead to issues in the future. Do things right once and never worry about it again.
I just updated it with nice bright colors too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jago »</TD></TR><TR><TD CLASS="quote">intake .006
exhaust .007</TD></TR></TABLE>
WRONG!!!! you need to include the range
Intake -.006-.007
Exhaust - .007-.008
lets make sure we distribute correct info
Intake -.006-.007
Exhaust - .007-.008
Quoted from the write-up. "recommend using .006 for intake, .007 to check, and .008 for exhaust with .009 to check"
Intake: .006 in.
exhaust: .008 in.
This is how I did mine and it sounds and feels great.
Intake: .006 in.
exhaust: .008 in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99LudeDude »</TD></TR><TR><TD CLASS="quote">Quoted from the write-up. "recommend using .006 for intake, .007 to check, and .008 for exhaust with .009 to check"
Intake: .006 in.
exhaust: .008 in.
This is how I did mine and it sounds and feels great.</TD></TR></TABLE>
correct...i see he likes to keep em tight as possible but im confused why not putting the exhaust closest to .007 and checking it with .008
when i did mine..i put the intakes closest to .006 and exhausts to .007..
just a word of warning in case anyone doesnt know..err on the side of loose..make sure the .006 and .007s come through with slight drag.. because too tight will f your day up
Intake: .006 in.
exhaust: .008 in.
wagon-r
Jun 11, 2013 09:32 AM
