Car smoking need help!!!!!!!!!!
I dont understand it when I drive my car under acceleration or just crusing I get no smoke at all it drives perfect. Lets say i let off the gas for a second and get back on it I will see smoke come out of my exhaust (bluish) and i smell oil definately but it only happens when i do this. Any Ideas????? Could it be my PVC valve?
to be quite honest with you guys, it isn't worth rebuilding. After getting head work, replacing parts, and so forth, you could have already bought a better motor. Ask anyone and I'm sure they will tell you the same thing. If you don't want to spend a ton of money, do a mini me swap or just buy a complete sohc vtec motor. If you have money to spend, just go Dohc. But this is just my .02 cents
I hear ya bro. My car is doing the same ****. Other than my headgasket went too!!! Rings arent too hard to replace. Spendy if you dont do the work yourself though.
I think you would be better off getting a newer block and forget paying the little bit more for a rebuild.
Actually I just had my motor rebuilt (3000 miles) and I fixed the problem this past weekend it was my PVC valve I put in a new one and all is solved I dunno about the rest of ya but give it a shot. All I need now is a Valve cover gasket they always got the sohc parts in da store but when you tell them its a dohc its always a special order part.
