Question on a Tick.
Old Apr 27, 2006 | 10:27 PM
De_tour's Avatar
Default Question on a Tick.
Modified by De_tour at 8:33 PM 4/17/2007
Old Apr 27, 2006 | 10:33 PM
MiX's Avatar
MiX
bump, have similar problem
Old Apr 27, 2006 | 10:36 PM
De_tour's Avatar
Default Re: (MiX)
Old Apr 28, 2006 | 09:48 AM
De_tour's Avatar
Default Re: (wspcivic)
bump
Old Apr 28, 2006 | 10:09 AM
schardbody's Avatar
my hatch has the same noise, sounds like a bad cv joint in the rear, i am leaning towards the back glass flexing on turns, but who knows.
Old Apr 28, 2006 | 11:53 AM
De_tour's Avatar
Default Re: (schardbody)
Old Apr 28, 2006 | 11:58 AM
onePOINTsix's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">my hatch has the same noise, sounds like a bad cv joint in the rear, i am leaning towards the back glass flexing on turns, but who knows.</TD></TR></TABLE>there is no CV in the rear... unless you have a MR converted civic lol anyway it sounds kinda like a wheel bearing
Old Apr 28, 2006 | 12:15 PM
d-man88's Avatar
Default Re: (onePOINTsix)
umm i think he meant it sounds SIMILAR to having a bad CV joint, only the sound is coming from the rear of the car, not that he is having problems with an actual CV joint in the rear.
Old Apr 28, 2006 | 12:19 PM
schardbody's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onePOINTsix &raquo;</TD></TR><TR><TD CLASS="quote">there is no CV in the rear... unless you have a MR converted civic lol anyway it sounds kinda like a wheel bearing</TD></TR></TABLE>
you dont think i know that seeing as how i am ASE certified master tech and all. i was describing the noise, not possible problem. im almost certain the noise is the hatch glass flexing.
Old Apr 28, 2006 | 12:45 PM
De_tour's Avatar
Old Apr 28, 2006 | 12:58 PM
schardbody's Avatar
jack it up and spin the wheels, if it fells rough then its a bad bearing.
Old Apr 28, 2006 | 01:24 PM
De_tour's Avatar
Old Apr 29, 2006 | 12:59 PM
De_tour's Avatar
b u m p
Old Apr 29, 2006 | 04:10 PM
De_tour's Avatar
bump
Old Apr 29, 2006 | 05:51 PM
pynikal's Avatar
i am havingthe same problem with my hatch, but it happens in the front and its at more so lower speeds when turning cvs are fine im clueless as to what could be causing this?? hate to semi jack the thread but if there is any insight on this it would be welcome.
Old Apr 29, 2006 | 06:09 PM
The Internet Tough Guy's Avatar
Default Re: (pynikal)
put the car on the ground, loosen the rear lca bolts you tightened while it was on jackstands, and torque them to spec.
Old Apr 29, 2006 | 08:12 PM
JeffBro's Avatar
Default Re: Question on a Tick. (wspcivic)
I have the same thing on my 96 coupe. I believe its the shock bushing on the lca(the first picture). This is my hunch because when I replaced my trailing arm bushings it didnt go away. Right after I replaced the T/A bushings i tried spraying lube on the shock bushings and it went away for like a week and then came back and mine look like yours and are cracked on the bottom.
BTW: Mine sounds like a creeking noise coming from the back when I pull into driveways.
Old Apr 29, 2006 | 09:20 PM
drevinder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">jack it up and spin the wheels, if it fells rough then its a bad bearing.</TD></TR></TABLE>
yes u suppose to do that ..........but u also suppose to grab the strut/spfing and feel for any viberation to know if it's the wheel bearing ...
Old Apr 30, 2006 | 01:27 AM
De_tour's Avatar
Default Re: (drevinder)
Modified by De_tour at 8:34 PM 4/17/2007
Old Apr 30, 2006 | 01:33 AM
ZipTieGUy's Avatar
I HAD THIS EXACT SAME PROBLEM WHEN TURNING RIGHT AND SOMETIMES ACCELERATING. AFTER I CHANGED MY REAR SHOCK, SPRING, AND LCA IT WENT AWAY. CHANGED IT ALL AT ONCE SO NOT SHURE WHICH ONE BUT I KNOW ITS THE RIGHT SIDE CUZ I DID THE LEFT SIDE FIRST AND THE NOISE WAS STILL THERE
Old Apr 30, 2006 | 01:37 AM
De_tour's Avatar
Default Re: (ZipTieGUy)
Old Apr 30, 2006 | 01:11 PM
jdeemseerx's Avatar
change your lower control arm bushings
Old Apr 30, 2006 | 01:22 PM
schardbody's Avatar
mine does it on left turns, but i dont think im getting the same problem as you all. mine is very very hard to hear, almost cant hear it at all, and im almost certain its just the body or glass flexing.
Old Apr 30, 2006 | 06:51 PM
De_tour's Avatar
Modified by De_tour at 8:35 PM 4/17/2007
Old Apr 30, 2006 | 10:14 PM
eg4usdm's Avatar
drifted?
