Short shifter for 92 Accord
Honda-Tech Titanium Member
Is there a short shifter for a 92 Accord? If there is would it work with the h22 tranny? I see the OBX short shift adapter on ebay, but I'm not really sure about it.
sorry man I didn't quite understand what you said. Did you say that it will fit the h22 tranny? Since I can't find any other short shifter on ebay other than the OBX adapter, can I use a short shifter for a prelude?
yes, i think pspec and forbidden shortshifters can be made to work in 4th gens if they dont already make specific applications, also you can use any prelude shift lever for a little difference...
Id prob. go for the Neuspeed short shifter. Even tho you wont get the 'look' of a short shifter. I always wanted to get a prelude shifter (shorter by i think 1") installed plus a Neuspeed short shifter .. but I donno if the prelude shifter will be a bolt on or what .. and weither you need just the lever or the whole box.
hey i went and rigged up a short throw shifter and it works fine the neuspeed one worked even better but i cant use it on a 90 thats why i dont have it on and how will it hurt the tranny it just makes the throw on the **** shorter it is still the same on the tranny and also I just cut the shifter down right above the neuspeed kit and cut right below the threads and welded it took off a good inch and a half to make it look shorter also
Modified by BlUAc at 8:15 PM 4/29/2006
Modified by BlUAc at 10:46 AM 4/30/2006
