gsr sway bar on a eg quetions???
B A N N E D
From: Orange County / Palm Springs 714/76hoe, ca, usa
i already got my strut and found out that my subframe can take 14mm sway
NOW HERE another question the guy who sold me the sway bar didnt give me the bolts that goes to the sway bar bracket to the subframe
do i need just a bolts or i need a bolts and nuts for the bracket
thanks in advance
Modified by spoon95eg at 6:29 PM 4/28/2006
thanks in advance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voyage34 »</TD></TR><TR><TD CLASS="quote">yes. the stock gsr bar is a 14mm bar, which the eg subframe is more than capable of handling.</TD></TR></TABLE>
Couldn't said it better.
You will need nuts bolts and washers, as well as locking washers (4) this is what I did. I wish I could remember what sizes though.
just go to the store with the bar endlink and the mounting bracket and fit a few bolts, the bolts that fir to the subframe only need to be an inch long if that and use a locking washer on the backside of the subframe so it doesnt come loose, the bolt connectind the endlink to the lca needs to be 2 inches long and use a washer on both sides. make sure you but the grade A bolts or airplane grade hardware so it never rusts.
Cuong-nutz
10
Oct 26, 2005 07:13 PM
