throttle cable probz?
Old Apr 27, 2006 | 06:14 PM
efyou's Avatar
Default throttle cable probz?
well im sure it is...but when i come to a stop..my car idles high...about 1.5 2 k...and if i put my foot behind my gas pedal and push towards me, the idle drops to normall...is my cable jus worn out? it is the original one i believe.
Old Apr 27, 2006 | 06:20 PM
tractionless's Avatar
Default Re: throttle cable probz? (efyou)
i had the same problem! just adjust the cable at the throttl body until it reads the correct rpms! mine was idling at 3k then i adjusted it down to around 750-800rpms
Old Apr 27, 2006 | 06:34 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efyou &raquo;</TD></TR><TR><TD CLASS="quote">well im sure it is...but when i come to a stop..my car idles high...about 1.5 2 k...and if i put my foot behind my gas pedal and push towards me, the idle drops to normall...is my cable jus worn out? it is the original one i believe.</TD></TR></TABLE>
Mine does the EXACT same thing. Sometimes it works fine, but sometimes it "sticks." I think it could be the pedal "return spring" also...
Old Apr 27, 2006 | 08:56 PM
theinfamouskonrad's Avatar
Default Re: throttle cable probz? (Tippyman)
or throttle body is getting stuck
Old Apr 28, 2006 | 09:40 AM
strictlyimport's Avatar
Loosen your cable. there should be some play in it.
bk7794
13
Jun 21, 2012 08:17 PM
Juccord
May 1, 2006 10:12 AM
delamission
Jan 21, 2006 03:15 PM
bseries_beast
Jul 2, 2004 09:25 PM
graphic
Oct 23, 2003 06:35 PM
