Honda S2000 Honda S2000
Nominal leakdown test numbers for a f20c with 45k
Old Apr 27, 2006 | 06:09 PM
Chubz's Avatar
Default Nominal leakdown test numbers for a f20c with 45k
Nominal leakdown test numbers for a f20c with 45k?
My compression is 216, 216, 216, 214. Those numbers are lower than my ol d numbers i had before i sucked some water up.
Old Apr 27, 2006 | 06:14 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: Nominal leakdown test numbers for a f20c with 45k (Chubzilla)
240-250.. though I don't know for sure because I'm drunk and my manual's at home.
Old Apr 27, 2006 | 06:15 PM
Chubz's Avatar
Default Re: Nominal leakdown test numbers for a f20c with 45k (FR-MOB: Projekt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt &raquo;</TD></TR><TR><TD CLASS="quote">240-250.. though I don't know for sure because I'm drunk and my manual's at home. </TD></TR></TABLE>
i know nominal compression is 228 according to the service manual,
Old Apr 27, 2006 | 06:18 PM
* B A N N E D *
Well you got me... but your compression is even accross the cylinders.. either it means they're all fine, or they're all leakin a bit.
Old Apr 27, 2006 | 06:24 PM
Chubz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt &raquo;</TD></TR><TR><TD CLASS="quote">Well you got me... but your compression is even accross the cylinders.. either it means they're all fine, or they're all leakin a bit.</TD></TR></TABLE>
yeah the evenessis good, but if anything is over 5 percent on the leakdown test when at operating temp then something isnt right. i dont know why they didnt tear it down like my insurance company requested. tomorrow im going to go there and tell them to just tear it down, becuase, i dont want to be driving two weeks down the road and a rod snap causing me more stress and problems that i need. You think im wrong for me wanting them to go over this carefully.
* B A N N E D *
Good choice. Just hope your insurance company backs you up.
Old Apr 27, 2006 | 06:25 PM
Chubz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt &raquo;</TD></TR><TR><TD CLASS="quote">Good choice. Just hope your insurance company backs you up.</TD></TR></TABLE>im sure they will, because im sure there not gonna want to end up paying more a month from now, when everything is grenaded
Old Apr 27, 2006 | 06:29 PM
* B A N N E D *
If they're smart they'll listen to us!
Old Apr 27, 2006 | 10:32 PM
evil vapor's Avatar
Those numbers are fine. They aren't too far off and consistency is what counts. Chances are the gauge used is inaccurate or not calibrated.
Old Apr 28, 2006 | 07:09 AM
Chubz's Avatar
Default Re: Nominal leakdown test numbers for a f20c with 45k (vapor)
bwahahahah 10 to 15 percent leakdown in every cylinder, on a 45 k motor and there trying to tell me thats good
talked to my insurance company and they said there going to ge the prraiser out there asap. Calle dup another honda dealer and they told me that 10-15% is way to high. My insurance claims agent, said that they will not put be back in this car if im not okay witht those numbers,
The techt hat did the leakdown test said honda has no standards when it comes to leakdown tests.
Modified by Chubzilla at 11:27 AM 4/28/2006
Old Apr 28, 2006 | 08:37 AM
* B A N N E D *
Wow. No standards? Never heard that one before. So 25% leakdown wouldbe ok?
Old Apr 28, 2006 | 08:44 AM
Chubz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt &raquo;</TD></TR><TR><TD CLASS="quote">Wow. No standards? Never heard that one before. So 25% leakdown wouldbe ok?</TD></TR></TABLE>
was told anything over 40 percent is bad
Old Apr 28, 2006 | 08:55 AM
* B A N N E D *
At 40% I'd rip my motor apart.
Old Apr 28, 2006 | 09:02 AM
Chubz's Avatar
you would think theyd be all over getting a replacement block, so i wont run into further issues, because the techs and service advisor said that it was a possibility that i could drive two weeks from now and a rod could go loose or anything else related to this, and thats what i told my insurance agent and she said if, i dont like wha this honda dealer says, i can take take it elsewhere
Old Apr 28, 2006 | 12:58 PM
Chubz's Avatar
well yet another update to the update.
the appraiser came out and the mechanic told him that the numbers were okay however my service advisor presented him the info i gave her stating the leakdown numbers are not good at 10-15 percent in each cylinder on this motor. So the appraier asked the honda advisor to call the honda technical department to find out if those numbers are bad...
should i continue praying that the honda technical department will say those numbers are too high ?
Old Apr 28, 2006 | 07:09 PM
Chubz's Avatar
found out from s couple of dealers that 7 percent is the cutoff point for a leakdown test, especially on a car like the s2000
Old Apr 29, 2006 | 08:57 AM
* B A N N E D *
So there's your answer Chubz. Hope the tech doesn't come back and tell you that 15% is ok. At least now you have backup.
Old Apr 29, 2006 | 12:34 PM
tegsallgood's Avatar
i wouldnt drive it man.... do whatever you can to get it up to par. thats def. not something you wanna expletive around with. seems like ur claims adjuster is being super helpful which is always good, when my ******* teg got stolen i was under a 2 month investigation. ****** statefarm lol.
Old May 1, 2006 | 10:27 AM
Chubz's Avatar
Default Re: Nominal leakdown test numbers for a f20c with 45k (tegsallgood)
well corporate honda said they have no guidelines as far as leakdown numbers and a tech fromt here said as long as the numbers are in the green zone, its fine.....I faxed over a letter to my appraiser and my insurance adjsuter stating that those numbers arent fine, and listed the potential problem I can incur if theres unseen or unchecked damage internally. I told them I wouldnt feel comfortable or safe driving the car, becuase nothing has been fixed, or bandaided
Old May 1, 2006 | 10:29 AM
Nishant's Avatar
can you take it to another dealer? The tech doesn't seem that great based on what he/she has done.
Old May 1, 2006 | 10:37 AM
Chubz's Avatar
Default Re: Nominal leakdown test numbers for a f20c with 45k (Nishant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant &raquo;</TD></TR><TR><TD CLASS="quote">can you take it to another dealer? The tech doesn't seem that great based on what he/she has done.</TD></TR></TABLE>
yeah im going too. My insurance adjsuter told me that regardless of what or what honda doesnt find, theyll decide what they should do.
joey1320
Honda S2000
Feb 19, 2008 05:33 PM
r1de4life
Jun 10, 2007 04:32 PM
berettagtz117
Mar 6, 2007 04:09 PM
dbiker207
Nov 26, 2006 07:10 AM
snowblind7x
Apr 13, 2005 08:12 PM
