EXHAUST RATTLE ---- SORRY FOR REPOST
Old Apr 27, 2006 | 04:53 PM
RUBZERK's Avatar
Default EXHAUST RATTLE ---- SORRY FOR REPOST
I know this has been asked b4 but i did a search & it does not have the info.
what is the fix for the 2000rpm rattle ????
Old Apr 27, 2006 | 05:24 PM
fw190bvi's Avatar
Default Re: EXHAUST RATTLE ---- SORRY FOR REPOST (RUBZERK)
there are a number...all of which i will be trying sometime soon...
on mine, it definantly appears to be caused by nothing more than the frequency of the exhaust gases resonating the piping....
Old Apr 27, 2006 | 06:21 PM
BLKFLSH's Avatar
Default Re: EXHAUST RATTLE ---- SORRY FOR REPOST (Teh FW CXCbVI)
An exhaust should be tuned to the engine. That's why I believe in keeping it stock. Just one cheap muffler made my car feel like the engine was coming apart. I learned my lesson quick, and got a new stock muffler the next time.
Old Apr 28, 2006 | 03:28 AM
RUBZERK's Avatar
Default Re: EXHAUST RATTLE ---- SORRY FOR REPOST (BLKFLSH)
I only get the rattle at 2k rpm.
Old Apr 28, 2006 | 07:41 AM
importfanatic17's Avatar
I have noticed in my car too that the vibrations at a lower RPM is more prominent than at higher revs. Anyway, is it coming from the muffler section or the midpipe? Do you still have the heat shields installed, it could be those? Tell us what section it is and that'll help more.
Old Apr 28, 2006 | 04:08 PM
RUBZERK's Avatar
Default Re: EXHAUST RATTLE ---- SORRY FOR REPOST (importfanatic17)
I thinbk the sound is comming from the cat area
Old Apr 29, 2006 | 07:37 PM
Have you checked the heat shields? Jack your car up and listen to where the rattle is. If it is a shield, you will most likely see it, otherwise, listen to where it is coming from and then remove that section and reinstall it.
Old Apr 29, 2006 | 07:46 PM
fw190bvi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKFLSH &raquo;</TD></TR><TR><TD CLASS="quote">An exhaust should be tuned to the engine. That's why I believe in keeping it stock. Just one cheap muffler made my car feel like the engine was coming apart. I learned my lesson quick, and got a new stock muffler the next time. </TD></TR></TABLE>
actually, this occurs on the stock system....just as bad
unfortunatley, you've never owned a 5th gen, so you've never had the pleasure...but its one of the common problems, along with tearing of driver side bolsters on leather seats, failure of the master power window switch causing the windows not to roll back up, failure of the power antenna, failure of ABS due to a $.07 part, etc....
Old Apr 29, 2006 | 07:51 PM
iam7head's Avatar
cat heat shield?
Old Apr 29, 2006 | 08:15 PM
accord-pro's Avatar
first off chk all the heat shields. also make sure you don't have a middle exh pipe that came apart internally ,,,,,and finally there is a bulletin on this ,94-041, buzz at around 1800-2200 rpm,, there is a kit which includes gaskets, bolts, and nuts for the ( mid pipe ) small pipe right after the frt exh pipe and the cat
Wdpfreak145
15
Jul 22, 2011 12:24 PM
rico892002
Jun 17, 2009 07:33 PM
blumpfish
12
Jun 23, 2006 03:06 PM
iphatcrxi
Aug 10, 2005 10:20 PM
JonGP4
Jun 30, 2003 12:30 AM
