OBX Diff clearance question.
Old Apr 27, 2006 | 01:27 PM
Tuned1's Avatar
Default OBX Diff clearance question.
I am coming up w/ .034 clearance between the diff bearing and the case. And the smallest shim that I have found Honda to make is .039
There is .000 gap between where the bearings are pressed/sit against the diff. So they are pressed all the way on. So from anyone who has had this same problem, any suggestions on what I can use for a .030 shim? I probably will just have one made but I just thought I would ask. This is the second one out of 7 that I have installed to have this same issue. The last one I found a solution for. This one I'll leave up to you guys.
Modified by Tuned1 at 2:41 PM 4/27/2006
Old Apr 27, 2006 | 02:24 PM
non-VTEC's Avatar
Default Re: OBX Diff clearance question. (Tuned1)
you can take the thinnest shim and grind it down a little to get the proper clearance.
i also remember someone using a used oil control ring from a old used piston to get the proper clearence......
Old Apr 28, 2006 | 10:40 AM
Tuned1's Avatar
Yeah I already considered the oil ring idea. A good freind of mine is a machinest. He said he has it covered for me. I just thought I would try asking around first. Thanks though.
mike703
Apr 15, 2012 07:35 PM
Kista20
Aug 17, 2008 06:11 PM
GSR_hatch936
13
Apr 20, 2007 10:24 AM
SkRiBLaH
Apr 30, 2005 06:49 AM
