MSD inline fuel pump-need filter!!!
I've got an MSD inline fuel pump and RCI fuel cell, but I need to know if there is any companys out there that sell an inline filter with hose barb fittings that can be used for mpfi efi systems? Summit Racing says no one makes one. Should I just use the stock fuel filter instead??
Need help A.S.A.P.
-ERIK
Need help A.S.A.P.
-ERIK
I don't know if this helps but I used an accel filter from summit with my inline MSD. It was the lowest price and you can thread fittings in it easily.
I'm using 3/8 lines too
So do you guys only run one fuel filter on drag cars then? Will that Accel filter handle about 40psi of fuel pressure??
-ERIK
-ERIK
your talking about Earls filters right?? Not trying to be a noob, but I just don't want to hurt my pump or injectors or start a fire because of a shitty filter.... thanks for the help.
Also, do I have to have 2 fuel filters? 1 before and 1 after the pump???
Thanks,
-ERIK
Thanks,
-ERIK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dseriesdrag »</TD></TR><TR><TD CLASS="quote">Will that Accel filter handle about 40psi of fuel pressure??</TD></TR></TABLE>
Yeah, the accel filter is an EFI filter.
Ok, so I just recieved my Accel fuel filter in the mail today, but what is a "saginaw thread"??? Is that the kind of threads that are on standard brass hose barb fittings at Lowe's or Home Depot????
-Erik
-Erik
What fuel line is everyone using for the drag cars?
I see braided then I see regular fuel line.
does it really matter what kind you use.
