MSD inline fuel pump-need filter!!!
Old Apr 27, 2006 | 11:46 AM
dseriesdrag's Avatar
Default MSD inline fuel pump-need filter!!!
I've got an MSD inline fuel pump and RCI fuel cell, but I need to know if there is any companys out there that sell an inline filter with hose barb fittings that can be used for mpfi efi systems? Summit Racing says no one makes one. Should I just use the stock fuel filter instead??
Need help A.S.A.P.
-ERIK
Old Apr 27, 2006 | 12:41 PM
WillieWillieFast's Avatar
Default Re: MSD inline fuel pump-need filter!!! (dseriesdrag)
Is this what you are looking for?
Old Apr 27, 2006 | 12:46 PM
Default Re: MSD inline fuel pump-need filter!!! (WillieWillieFast)
yes, but i need hose barb fittings, not -AN fittings.
-ERIK
Old Apr 27, 2006 | 12:51 PM
tony1's Avatar
Just get some an to barb adaptors.
Old Apr 27, 2006 | 12:59 PM
Default Re: MSD inline fuel pump-need filter!!! (tony1)
so I can get those from Earl's of Russell??
Thanks tony1,
-ERIK
VisualAutoMotoring's Avatar
What size barb fittings?
Old Apr 27, 2006 | 01:09 PM
Default Re: MSD inline fuel pump-need filter!!! (Hybrid-Performance.com)
3/8 preferebly...
-ERIK
Old Apr 27, 2006 | 02:47 PM
I can check tommorow. The place i maybe able to get it from is closed already
Old Apr 27, 2006 | 08:01 PM
The Original Whitey's Avatar
I don't know if this helps but I used an accel filter from summit with my inline MSD. It was the lowest price and you can thread fittings in it easily.
I'm using 3/8 lines too
Old Apr 28, 2006 | 03:11 PM
Default Re: MSD inline fuel pump-need filter!!! (The Original Whitey)
So do you guys only run one fuel filter on drag cars then? Will that Accel filter handle about 40psi of fuel pressure??
-ERIK
Old Apr 28, 2006 | 04:24 PM
Project-D's Avatar
I used a Ford Escort GT Fuel filter! Worked great!
Cheap and I flowed 80psi through it!
Old Apr 28, 2006 | 05:27 PM
slvrstns2000's Avatar
Default Re: (Project-D)
just go with earls, got mine today..i like
Old Apr 28, 2006 | 10:00 PM
Default Re: (flatblackEK)
your talking about Earls filters right?? Not trying to be a noob, but I just don't want to hurt my pump or injectors or start a fire because of a shitty filter.... thanks for the help.
Also, do I have to have 2 fuel filters? 1 before and 1 after the pump???
Thanks,
-ERIK
Old Apr 29, 2006 | 01:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dseriesdrag &raquo;</TD></TR><TR><TD CLASS="quote">Will that Accel filter handle about 40psi of fuel pressure??</TD></TR></TABLE>
Yeah, the accel filter is an EFI filter.
Old Apr 29, 2006 | 05:38 PM
ok, thanks for the help guys!
-ERIK
Old May 9, 2006 | 05:48 PM
Ok, so I just recieved my Accel fuel filter in the mail today, but what is a "saginaw thread"??? Is that the kind of threads that are on standard brass hose barb fittings at Lowe's or Home Depot????
-Erik
Old May 10, 2006 | 04:19 AM
ReDemoN's Avatar
DixielandImports Please
What fuel line is everyone using for the drag cars?
I see braided then I see regular fuel line.
does it really matter what kind you use.
turbo-crx
Sep 9, 2008 10:31 AM
98AccordEX
Jan 9, 2004 04:08 AM
