Question about Skunk 2 PRO 1's and how they idle
Old Apr 27, 2006 | 11:14 AM
wildoutwhitegsr's Avatar
Default Question about Skunk 2 PRO 1's and how they idle
Ok I've just spent the past couple of days going thru the archives of old skunk 2 pro 1 threads trying to find out what they idle at and the info about them is sketchy at best.
I've talked to my local tuner and he said they idle around 1000-1200rpm and it is a rough idle. So I'm putting the question out there.
Has anyone gotten the Skunk 2 PRO 1's to idle at 850rpm? If not what's the range they idle at?
So far things I've read up on to get them to idle smoothly, +2 intake +2 exhaust for cam gear settings. I understand this is different based on the setup so I'm just using it as a guide.
They require 15:1 a/f ratio at idle.....is this tru? I find this hard to believe.
and they have a lumpy idle. They wouldn't be smooth.
These are just the things I've read up on here and my tuner has confirmed this some what, but told me he didn't have enough time to tune them more for other reasons. He has only had one set to tune.
Please any help given is appreciated
Modified by wildoutwhitegsr at 3:33 PM 5/16/2006
Old Apr 27, 2006 | 12:05 PM
UncleD's Avatar
Default Re: Question about Skunk 2 PRO 1's and how they idle (wildoutwhitegsr)
To get them to idle correctly you need to take away some fuel at idle. My roomate got his to idle at around 900-950 and they sounded almost like stock. PM El_Capitan here on H-T...he can tell you exactly what he had to do.
Old Apr 27, 2006 | 12:47 PM
EK Josh's Avatar
Default Re: Question about Skunk 2 PRO 1's and how they idle (clean rice)
I'd like to know as well. I'm debating between these and bcIV's and the idle is one of the deciding factors.
Old Apr 27, 2006 | 12:49 PM
Tbone's Avatar
Did a set last night. they idle about 900 @ 15.1 af.. I bumped it up to 1100 though so it will never stall after throttle tip in.
Old Apr 27, 2006 | 01:49 PM
DonF's Avatar
Default Re: Question about Skunk 2 PRO 1's and how they idle (Tbone)
850-900 if you know what you are doing, and have an adjustable ECU.
Old Apr 27, 2006 | 04:59 PM
an2ny888's Avatar
Default Re: Question about Skunk 2 PRO 1's and how they idle (DonF)
mine idle decently at 850, only when it's warm though. cold start is still very lumpy, surges a bit.
Old Apr 27, 2006 | 06:05 PM
Combustion Contraption's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">850-900 if you know what you are doing, and have an adjustable ECU. </TD></TR></TABLE>
My ECU is adjustable. I can pivot it left and right. Does this mean i can install OBX VTEC Eliminators?
Old Apr 27, 2006 | 08:20 PM
B20C5 Turbo's Avatar
New User
I selected the Pro 2's for my brothers car. I've achieved a stable Idle at 900 rpm with excellent throttle response, but it's a little 'lopey' due to the higher compression and ultra-light flywheel.
Old Apr 27, 2006 | 10:09 PM
Thanks a lot guys
Been researching a bit more and one said to have the timing at 20-22 degree base timing. He did have it running more on the richer side at idle though with 13.5-13.8 a/f ratio. I assume this is to prevent detonation because of the advanced timing.
Tyrant_007
Mar 28, 2011 08:01 PM
Hyaboosta
Jul 13, 2005 02:14 PM
DelSolSi93
Sep 5, 2004 08:27 PM
k20
Jul 5, 2004 02:05 PM
