a/c question
a/c question i have a b16 in my 93 hatch back I need to know what a/c lines I have to use I know that I have to use 94 and up because its r134a I have a B16 compressor and I'm not sure if I have to use Soch a/c lines that connect to the compressor or B16 civic SI or other a/c lines please helps thank u
if your car had a/c before the swap, you can use your d-series compressor. all you need is a p54 del sol dohc vtec bracket. and your compressor will bolt right up. that's the easy way. i heard of ppl getting custom a/c lines to fit the b-series compressor but i didn't really get into depth with it. hope that helps....
You can also use the AC bracket & pulley from the CRV to retain you D series compressor. It is much cheaper than the Del Sol VTEC one, and much easier to get. You'll have to do a little research to get the exact part number...
Also, you can convert your R-12 system to R-134 without replacing all the lines. You just need to have the system flushed & filled w/ the proper compressor oil & have new R134 service fittings put on...
if you have the stock a/c lines and a b-series comp. then no the lines won't fit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! »</TD></TR><TR><TD CLASS="quote">
Also, you can convert your R-12 system to R-134 without replacing all the lines. You just need to have the system flushed & filled w/ the proper compressor oil & have new R134 service fittings put on...</TD></TR></TABLE>
92 93 civics has r-12. 94 95 has r134a.
lhd dc2
Aug 11, 2005 04:10 PM
Tuner Eddy
Jun 8, 2005 08:02 AM
