1991 Accord windshield wiper problem? HELP !!!!
Old Apr 27, 2006 | 07:12 AM
tedog69er's Avatar
Default 1991 Accord windshield wiper problem? HELP !!!!
When my windshield wipers are not on I can grab them and there is about a 2.5 in. play in the movement of them up and down. I checked my buddy's 94 and he had 0 play in his. Anyone have any ideals if this could be the motor or linkage? THanks for your time.
Old Apr 27, 2006 | 09:02 AM
Ross 2.0's Avatar
In a Junkyard near you.
Your wiper transmission has some play in it but it's really no big deal unless it quits working. You can replace the joints in the transmission or just buy a new one.
Old Apr 27, 2006 | 09:31 AM
tedog69er's Avatar
Default Re: (MooGoCow3)
Is that in the actual motor ?
Old Apr 27, 2006 | 09:32 AM
tedog69er's Avatar
Default Re: 1991 Accord windshield wiper problem? HELP !!!! (tedog69er)
Because when I turn on the wipers it goes about 2in. to far over to the left and then slams back down at the bottom really anoying
Old Apr 27, 2006 | 10:35 AM
Ross 2.0's Avatar
your motor is probably fine. just put a new transmission on it and you'll be fine
Old Apr 27, 2006 | 11:01 AM
tedog69er's Avatar
Where would I find this Transmission for the wipers? Thanks
Old Apr 27, 2006 | 11:58 AM
Ross 2.0's Avatar
http://www.hondaautomotiveparts.com
junkyard
dealership
Any of them would work for you. Good luck
Old Apr 27, 2006 | 02:29 PM
Magnum99's Avatar
The problem is in one of the two rods that connect the motor/two wipers. There are teflon type inserts that pivot on a fixed ball. The teflon has worn out. You will have to find out which one of the two rods has the bad insert (usually the one directly attached to the motor). It will cost you about $20 for the whole arm, the teflon insert is molded onto the aluminum rod. Ive tried to fix broken ones but it is an exercise in futility.
Be careful when ordering the new one from your dealership the parts breakdown is not very detailed and the two can be easily mixed up, and they are different lengths. Or go to a junkyard and find one, only accord of that gen will fit.
Old Apr 27, 2006 | 02:32 PM
Magnum99's Avatar
Oh, I've assumed that you know to take the wipers off, and then the plastic shroud under the windshield. If you have any problems with that give another holler. cheers!
Old Apr 27, 2006 | 02:40 PM
accord-pro's Avatar
have you checked to make sure that the nuts holding the wiper arms are tight??
if so i would chk the linkages for wear ,
Old Apr 27, 2006 | 02:47 PM
Magnum99's Avatar
Default Re: 1991 Accord windshield wiper problem? HELP !!!! (accord-pro)
I've seen this more than once, on a 90 and on a very high milage 97, the problem will be as I described. If left unchecked it will eventually fall off and you will have no wipers. more than anything is the anoying slop in the wipers as they hop over the window or start cleaning the window trim. Real sloppy and annoying!
Old Apr 30, 2006 | 10:16 AM
tedog69er's Avatar
Default Re: 1991 Accord windshield wiper problem? HELP !!!! (Magnum99)
someone wouldn't happen to have a parts explosion diagram for this would they?
Old Apr 30, 2006 | 03:04 PM
accord-pro's Avatar
http://www.hondaautomotivepart...WIPER
try this ..
Old May 22, 2008 | 02:33 PM
Andryzzle's Avatar
back from the dead... when taking the actual wiper arm off.. I have the nut off of the top, then do I just have to pry the arm off? mine is on there pretty tight and I sprayed some wd40 on them so will try again. I don't like to use excessive force unless i know thats what im supposed to be doing. anybody have insight?
Old May 23, 2008 | 06:21 AM
professorman's Avatar
Default Re: 1991 Accord windshield wiper problem? HELP !!!! (Andryzzle)
I took off mine last weekend to repaint them. I did mine with the hood open, and I had to apply some force to the spring to balance out the force on it and lift up. After I did mine, I found this easier instructions. Just do it with the hood closed and lift up the arms like you are cleaning the windshield and just lift them straight up.
http://www.team-integra.net/se...D=538
Check out the link for more instructions.
Jessica1992
Dec 31, 2018 07:27 PM
yvonne nelms
Feb 4, 2016 08:04 AM
donee12
Apr 26, 2014 07:05 PM
lhodo
Aug 12, 2010 05:42 PM
jb.
Nov 27, 2007 02:09 PM
