Differential or Clutch?
Old Apr 27, 2006 | 06:08 AM
DOMKID's Avatar
Default Differential or Clutch?
I went to the track yesterday and i miss-shifted pretty bad from 3rd to 4th. I couldnt get into into gear so i coasted down the track. Once i managed to get it into gear i noticed a bad clutch shatter at low speeds. I did a burnout and then couldnt go forward. I check out the axles and they're physically not broken. Now i cant move at all. I can put it into any gear without hitting the clutch. If i put the tranny in 1st gear and push the car, it moves like its in neutral. I dont see any physical damages on the casing of the tranny.
There was a big scent of "clutch" the whole night. Could i have broken my differential or could it be my clutch?
tranny is a y21 JDM b16 w/o LSD
thanks for any advice/info.
Old Apr 27, 2006 | 06:14 AM
DaveSi677's Avatar
Default Re: Differential or Clutch? (Felix.)
could be the master cylinder to.... I had something similar but I stand corrected.
Dave
Old Apr 27, 2006 | 07:55 AM
HatchEh2's Avatar
Default Re: Differential or Clutch? (93SiVtec677)
but y would he be able to just slide the shifter in gear w/o resistence and the car just stays in neutral??? im trying to figure out what the expletive happened... cuz a friend of mine had the same happen to his ls tranny...
the **** was just a loose joystick that wobbled and didnt do anything in any gear... just stayed in neutral... he ended up just getting another tranny...
im sure you dont wanna hear that cuz you gotta nice tranny... but i think thats it bro
Old Apr 27, 2006 | 08:40 AM
hondaid's Avatar
Sounds like you blew the tranny good. Also what's your Rev limiter?? casue I've seen alot of "Tough guys" that'll remove they rev limiter, then rev the **** out of them to be cool.......then the next day they're bring them into my shop with Bent valves. So if you missed your gear Bad, as you said, and it reved out Really High.......you could have bent valves......just a thought
Old Apr 27, 2006 | 02:31 PM
Egyptian_Kid's Avatar
Default Re: Differential or Clutch? (hondaid)
its your five year old clutch dude
its time to get a new 1
Old Apr 27, 2006 | 03:00 PM
sihatch19's Avatar
throw out bearing or diff. .they both cant take too much abuse
Old Apr 27, 2006 | 05:20 PM
Targa250R's Avatar
be professional
This is a clutch-related problem. The fact that you can easily select a gear with the engine running and the clutch out indicates that the transmission input shaft is not spinning, so it is not being connected to the engine by the clutch.
Old Apr 27, 2006 | 05:23 PM
Runnerdown's Avatar
Default Re: (sihatch19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sihatch19 &raquo;</TD></TR><TR><TD CLASS="quote">throw out bearing or diff. .they both cant take too much abuse
No, the throw out bearing has NOTHING to do with this problem. It is likely the clutch disc fell apart
Old Apr 27, 2006 | 05:35 PM
naTRON's Avatar
i think Targa's got it right
Old Apr 27, 2006 | 06:24 PM
sihatch19's Avatar
SORRY runner
Old Apr 27, 2006 | 06:28 PM
Runnerdown's Avatar
I just dont like to see wrong info confusing anyone
Old Apr 27, 2006 | 07:32 PM
DOMKID's Avatar
Default Re: (Runnerdown)
thanks for the input guys,i will be dropping the tranny and taking pics.
my mechanic also thinks its my clutch.
Old Apr 27, 2006 | 07:35 PM
delslowhonda's Avatar
what about this one? shift linkage came partially loose. happened to me once, wasn't sure what the F happened. it wasn't all the way loose, i could get it in 3rd and 4th if i was lucky, but not any other gears at all. had to limp it home in 3rd gear
Old May 6, 2006 | 07:37 PM
DOMKID's Avatar
Default Re: (delslowhonda)
Could it be the axles?
Old May 16, 2006 | 06:02 PM
DOMKID's Avatar
Default Re: (Felix.)
Pulled the axles and they were fine. Pulled tranny and this is what i saw.
Debris inside the tranny.
ACT street disc
ACT presure plate, not sure if its HD or SS, came with my swap.
Time for a new clutch.
Old May 16, 2006 | 06:12 PM
G2 Speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Felix. &raquo;</TD></TR><TR><TD CLASS="quote">Pulled the axles and they were fine. Pulled tranny and this is what i saw.
ACT street disc
Time for a new clutch. </TD></TR></TABLE>
could someone explain to me what i'm looking at here.. i'm a tranny n00b? and I don't mean that is the clutch.. etc... like the debris and stuff
Old May 16, 2006 | 06:17 PM
EG2Driver's Avatar
Default Re: (G2 Speed)
i hope u had a mask, that stuff is no good in ur lungs.
Old May 16, 2006 | 06:19 PM
t0p_sh0tta's Avatar
#1 - clutch disc material that basically fell apart.
#2 - the actual clutch disc itself.
#3 - pressure plate.
Old May 16, 2006 | 06:24 PM
G2 Speed's Avatar
Default Re: (t0p_sh0tta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta &raquo;</TD></TR><TR><TD CLASS="quote">#1 - clutch disc material that basically fell apart.
#3 - pressure plate.</TD></TR></TABLE>
thanks, I knew 2 and 3...
but never knew that's what clutch disc material looks like
XES
Jul 18, 2003 09:22 AM
DefiantGSR
Jan 30, 2003 09:34 AM
tilt
Oct 7, 2002 01:22 PM
NickGSR
Sep 15, 2002 05:26 PM
eg_hybrid
Oct 6, 2001 08:27 AM
