is it safe to raise compression with a thinner head gasket?
Old Apr 26, 2006 | 07:56 PM
oranginal's Avatar
Default is it safe to raise compression with a thinner head gasket?
i have to take my head off and am wondering is it safe to raise compression with a thinner head gasket? like could problems arise?
i heard that messing with the compression can cause problems, but i would think that if anything it would only raise the compression slightly?
has anyone done this, and if so how thin do you go?
p.s. if it matters i am going to get the car tuned not sure if air fuel affect compression.
Old Apr 26, 2006 | 10:45 PM
soundbomber's Avatar
Default Re: is it safe to raise compression with a thinner head gasket? (oranginal)
should be fine.
Old Apr 27, 2006 | 07:02 AM
The_Sober's Avatar
Default Re: is it safe to raise compression with a thinner head gasket? (soundbomber)
it's safe as long as you check for adequate valve clearance, and you don't bump the compression up to absurdly high numbers
Old Apr 27, 2006 | 07:56 AM
Hawkze_2.3's Avatar
Yeah, the slightly higher compression won't be a problem, but you will need to check for clearance since the valves are now closer to the pistons.
Old Apr 27, 2006 | 08:04 AM
94Vtecluder's Avatar
Default Re: is it safe to raise compression with a thinner head gasket? (Hawkze_2.3)
Ya it's fine just check for clearance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Sober &raquo;</TD></TR><TR><TD CLASS="quote">it's safe as long as you check for adequate valve clearance, and you don't bump the compression up to absurdly high numbers</TD></TR></TABLE>
Shouldn't be a problem, a thinner headgasket won't raise compression nearly that much to be concerned about knock or anything the like.
Old Apr 27, 2006 | 08:38 AM
oranginal's Avatar
Default Re: is it safe to raise compression with a thinner head gasket? (94Vtecluder)
kinda noob question but -
how do i check 4 clearence? like is there a process or just a visual kinda check.
steps please if someone knows how
Old Apr 27, 2006 | 09:20 AM
Hawkze_2.3's Avatar
You can clay the engine, but that's not 100% because higher rpms may create tighter clearances.
Old Apr 27, 2006 | 09:42 AM
The_Sober's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">You can clay the engine, but that's not 100% because higher rpms may create tighter clearances.</TD></TR></TABLE>
good point.
I suggest you clay the engine, and add 5% to compensate for higher RPMs
Old Apr 27, 2006 | 12:52 PM
SrT4u2nV's Avatar
Default Re: is it safe to raise compression with a thinner head gasket? (The_Sober)
if i use clay do i have to put it together, then run it , take it apart and check the clay looking 4 clearence and then put it all back together again?
is there any other less time -consuming way?
i have an oem gasket and i hear that you can take out the middle layer to make it slightly thinnner, if i do this would it be okay or would it be safer to run the clay test?
Acura-Power
Acura TL, RL & ZDX
May 23, 2024 05:10 PM
High Reved Racing
Jul 14, 2008 04:37 PM
EG type GTR
Aug 13, 2006 09:05 AM
CALM_AS_A_BOMB
Mar 14, 2005 05:34 AM
aut0tek
Mar 18, 2003 11:00 AM
