engine mounts
which one is it? If they don't got it the honda dealership does. Is this for a D series swap? If so I'm pretty sure you can use the same mounts no problem.
its the mount on the engine, the one near the driver side tire well, i have the mount from the engine going in and the engine that came out but neither of them fit right, thery are designed totally different, its a 97 vtec from an ex into my 91 crx hf
You should be able to use the stock 88-91 CRX. I have the stock mounts w/ the d16z6 motor. Just order them from autozone or advance, I know they carry them.
Excelerate
May 16, 2006 07:13 AM
