cant turn (bouncing front)
Old Apr 26, 2006 | 06:40 PM
turbob16ef's Avatar
From: if you build it they will come, the bottom carolina, duh
Default cant turn (bouncing front)
i have a 90 crx si sith a ls swap, avid mounts. my problem is when ever i turn left and push the gas at higher rpms the car feels like something is loose(repeated hits like a drum). but when ever i am a lower or even higher rpms but not giving it a lot a gas it is really smooth. anyone have an idea of what this could be.
my susp. set up is kyb adjustables(not agx) with sportline springs. if that would help
thanks
Old Apr 26, 2006 | 07:55 PM
crxnj's Avatar
Default Re: cant turn (turbob16EF)
did you take out the dust sheilfds from inside the crx hubs? if not it would cause the axles to bind...or maybe your wheels arent balanced?? or bad axle(s) ?
Old Apr 27, 2006 | 12:03 PM
turbob16ef's Avatar
Default Re: cant turn (Mr.speaker)
i took the dust sheilds off. Double checked. and i have had 3 different sets of tires on the front. it is only the passenger side. i have check the tie rod and it is tight.
has anyone ever had problems with the tranny tapping the torsion bar, dont think it does it any more ,but, it might still be doing it i cant really feel it any more. it used to do it with different mounts
i dont know what it is. i have checked all of the bolts, and hub but still does it.
Old Apr 27, 2006 | 01:26 PM
tmeracz's Avatar
So to re-iterate: the problem occurs under load with the wheel cut hard to the left. You can enter the corner slowly or at high RPM with your foot off the gas & you DON'T hear the noises?
This is a tough one to narrow w/o more info. How old are your ball joints, steering rack bushings, tie rod ends, axles & halfshafts, swaybar endlinks etc? The extremes in geometry your suspension goes through under load in a corner won't manifest themselves when the car is parked and on the rack. Look very carefully.
I had a similar problem 2 years ago: B16 swap, Hasport mounts. It wasn't until I disassembled most of the front end and re-spec'ed every nut & bolt that the problem went away. I found quite a few loose bolts- including the passenger's side engine mount & I also re-seated my axles and wouldn't you know it, the left one popped in about a quarter inch!
Have you pulled off any extra pieces that could be coming into contact with the block or rear crossmember- such as the swaybar? I'm not familiar w/ your mount kit, but how are clearances with regard to radius rods, LCA's? With the exhaust & the swaybar? Thumps & bumps can come from odd places. In 90% of my experiences with Honda's of this age, it is coming from the suspension- worn out old ball joints or old steering rack components. Just food for thought. HTH
Old Apr 27, 2006 | 04:55 PM
Tippyman's Avatar
Blown shocks. Mine sounded like that when they blew...
of course, you'd prolly know it if it was...
Old Apr 28, 2006 | 04:11 AM
turbob16ef's Avatar
Default Re: (Tippyman)
i was told the front end was just rebuilt both driver and passenger. I guess it could be my shocks sense they were sitting on a car for about 5 years. i know that he rear crossmember wasnt hit enough so the elbow mount is really close to crossmember.
dont know what it is i guess i can go and take the whole side apart and put it back together
thanks for the help.
Old Apr 28, 2006 | 07:50 AM
boostedSI90hatch's Avatar
Banned
Default Re: (turbob16EF)
torque steer?? idk?
yblegal
Dec 21, 2010 09:25 AM
christion
Apr 9, 2007 04:06 PM
rattlecanjoe
Feb 16, 2007 12:48 PM
91edmvteccrx
14
Nov 15, 2006 03:06 PM
jerBEAR
Sep 27, 2006 05:14 AM
