Difference in b series oil pans
Old Apr 26, 2006 | 05:58 PM
fieromadman's Avatar
Default Difference in b series oil pans
i have a 94 ls motor i was wondering if a b16 oil pan will fit on it? The reason i need to know is cuz the b16 one already have a hole tapped out for a return line for a turbo!
Old Apr 26, 2006 | 07:04 PM
NJIN BUILDR's Avatar
Default Re: Difference in b series oil pans (fieromadman)
LS and B16 pans are interchangable.
Old Apr 27, 2006 | 07:22 AM
SkRiBLaH's Avatar
oil pans:
b16a = b18a/b
b18c1 = b18c5
Old Apr 27, 2006 | 10:08 AM
Walterronny's Avatar
Default Re: Difference in b series oil pans (NJIN BUILDR)
which is better?
Old Apr 27, 2006 | 12:13 PM
dpetro1's Avatar
b16 and ls have the same pan.
make sure the the hole tapped is in the right place for your setup though cause oil returns can vary in length and placement due to different manifold and turbo setups. you might be better off just pulling off your stock pan and tapping it yourself. its really easy.
Old Apr 27, 2006 | 12:15 PM
dpetro1's Avatar
Default Re: Difference in b series oil pans (Walterronny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Walterronny &raquo;</TD></TR><TR><TD CLASS="quote">which is better?</TD></TR></TABLE>
they are the exact same. one isnt better than the other.
Old Jun 8, 2006 | 12:42 AM
Cheeech's Avatar
Default Re: Difference in b series oil pans (SkRiBLaH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH &raquo;</TD></TR><TR><TD CLASS="quote">oil pans:
b16a = b18a/b
b18c1 = b18c5</TD></TR></TABLE>
Do either of these fit on a b20?
Old Jun 8, 2006 | 01:36 AM
rainforest's Avatar
Default Re: Difference in b series oil pans (CheechJDM)
yes the ls/b16a pan does the diff in the pana is because the gsr/type r has a girdle and needs more space and a different windage tray.
Old Jun 8, 2006 | 01:46 AM
Cheeech's Avatar
Default Re: Difference in b series oil pans (rainforest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rainforest &raquo;</TD></TR><TR><TD CLASS="quote">yes the ls/b16a pan does the diff in the pana is because the gsr/type r has a girdle and needs more space and a different windage tray.</TD></TR></TABLE>
Thanks now i can go buy me a LS oil pan
mportracer33
Mar 21, 2006 11:46 PM
SleepinTeg
Jun 17, 2005 06:21 PM
Hoffy
Apr 22, 2005 04:38 PM
RTW DC2R
Jul 3, 2004 02:57 PM
92hybridhhatch
Dec 1, 2003 06:05 PM
